'00 XJ Overheating - Bad Water Pump - Page 7 - JeepForum.com
post #91 of 93 Old 08-20-2012, 08:42 PM Thread Starter
njsurfmaster
After a few weeks of use, I think my overheating is fixed. While driving with or without the AC on it's back to staying at or below 210.
Thanks to everyone for your input on this!
Sean
njsurfmaster is offline
post #92 of 93 Old 08-21-2012, 09:00 AM
BillB7581
Originally Posted by njsurfmaster View Post
I've driven it for a couple of days now and with the A/C off it stays around 205 based on the gauge.
One thing that is strange (or at least different) is when I stop and turn the engine off the temperature on the gauge will rise. If I stop for 5 minutes and turn it back on, the temp on the gauge will have gone from 205 to maybe 212 or so. Seems like the coolant temp is rising from being in contact with the hot engine/head? I have never noticed this in the past. Once I run it for a few seconds, the temp goes back down.
Has anyone seen this? Is it an indication of anything?
Sean
This is normal. When you cut the car off, it still heats up but the fan isnt running and the water pump isnt circulating (heatsoak), once you start it back up the fan runs and the coolant cools back down.
BillB7581 is offline
post #93 of 93 Old 09-13-2013, 05:20 PM
hoochbear
for 2 years in 1980's the 4.0 had no radiator cap. does your '87 have this closed system like my '88? (no radiator cap?) My old Pioneer 4.0 liter had problem, turned out to be coolant reservoir and or/ blowout valve, the whole time. mechanic after trying almost everyyhing else, said" oh those go bad all the time" Bet i was frosted enought to cool down a D-9 Caterpillar!
hoochbear is offline
overheating
Overheating and water pump was the culprit racerex1 XJ Cherokee Technical Forum 0 09-03-2011 10:48 AM
overheating after water pump install! josh25050 XJ Cherokee Technical Forum 11 08-30-2009 03:55 PM
New Water Pump, now overheating. TheWombaT XJ Cherokee Technical Forum 9 10-20-2006 01:04 AM
Overheating problems after Water pump install xjmatt XJ Cherokee Technical Forum 20 08-18-2006 10:39 AM
New Water pump overheating bond3006 XJ Cherokee Technical Forum 7 05-04-2006 01:29 AM
