00 XJ 4.0 Valve Adjustment - JeepForum.com
post #1 of 12 Old 09-29-2012, 03:07 PM Thread Starter
rosco219
Well I am changing my valve cover gasket, so I figured I mine as well adjust the Valves while doing so... How do I do that? Ive adjust on my 68 VW bug and it was very difficult, Is this a simple task done with a feeler gauge ?
Thank you for the help
rosco219 is offline
post #2 of 12 Old 09-29-2012, 04:14 PM
cory4um
I was under the impression that the valves are not adjustable. If I'm wrong, someone will chime in.
cory4um is offline
post #3 of 12 Old 09-29-2012, 04:32 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The 4.0 L hydraulic lifters require no adjusting.
CJ7-Tim is offline
post #4 of 12 Old 09-29-2012, 07:14 PM
Dasquatch
Just put a head on mine.
Rocker Arm Assembly-to-Cylinder Head Capscrews
30 NĚ m
21 ft. lbs
Dasquatch is offline
post #5 of 12 Old 09-30-2012, 11:08 AM Thread Starter
rosco219
Are these metal pieces in the center of my valve cover supposed to be there??
rosco219 is offline
post #6 of 12 Old 09-30-2012, 11:08 AM
GetLifted
You mean gasket? Yes the one with a hole goes in the pin in the head.
GetLifted is offline
post #7 of 12 Old 09-30-2012, 11:11 AM Thread Starter
rosco219
In the pin in head? Do I need to remove something to attach this?
Also what are the Rubber grommets for and what do I do with them? This is a Felpro gasket
rosco219 is offline
post #8 of 12 Old 09-30-2012, 11:15 AM
GetLifted
The farthest metal strip on the gasket in that pic has a hole in it. That hole lines up with a fixed pin in the head.
Its only there to make sure you dont put the gasket on backwards.
*and imagine if those metal support strips were not there, you would have a hell of a time lining up the gasket if it was all flimsy.
post #9 of 12 Old 09-30-2012, 11:31 AM Thread Starter
rosco219
What about the grommets...Do they go under the valve cover inside the head bolt patterns? Or under the bolts above the valve cover?
rosco219 is offline
post #10 of 12 Old 09-30-2012, 11:43 AM
GetLifted
My gasket kit didnt have them lol
post #11 of 12 Old 09-30-2012, 04:52 PM
AZ Jeff
2014 JK Wrangler
They go on the bolts under the washer head.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #12 of 12 Old 09-30-2012, 05:03 PM Thread Starter
rosco219
Done, grommets were a PITA to get off the the washer seals, Hopefully no more leaky. Still so much crud from it leaking though..
rosco219 is offline
Valve Adjustment & Valve Spring Replacement srpope80 XJ Cherokee Technical Forum 6 05-29-2014 05:45 AM
valve adjustment snowcat XJ Cherokee Technical Forum 32 08-23-2012 11:01 AM
Valve stem seals? or valve lash? Godchsr XJ Cherokee Technical Forum 9 11-29-2007 01:28 PM
help me do a valve adjustment thesplintercell XJ Cherokee Technical Forum 3 04-15-2007 01:49 PM
Coolant Mixing Valve / Heater Valve Leaking - Tips needed JWeb_93YJ XJ Cherokee Technical Forum 5 03-13-2005 07:34 AM
