Quantcast `00 Rear Dana 35 noise when I let off gas - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > `00 Rear Dana 35 noise when I let off gas
Truck-Lite's New LED Headlamp SeriesRuffstuff Axle Simple Swap Kit!Spartan Lockers FREE SHIPPING Excellent Prices
Old 05-10-2009, 10:12 PM   #1
CherokeeErik
Sounds like a clunking noise when I let off the gas, more noticeable at higher speeds, speeding up to merge on and then letting off the gas a bit once im doin 60-70. Also heard sometimes around lower speeds.. I have a 3" skyjacker w/ 31 10.5s, I do have shaft vibe because I havent installed the transfer case lowering kit yet,the rear "had" alum lift blocks and they broke last year, I replaced them with solid steel plate and new U bolts, I checked the U bolts, they are tight, u joints are ok.. There is a little back and forth slop in the rear end, but it doesnt seem too bad.. output shaft on transfer case has slop up and down ( that doesnt seem right does it? ) it doesnt leak... ANY IDEAS???? Thanks
yes lug nuts are tight too
CherokeeErik is offline   Reply With Quote
Old 05-10-2009, 10:31 PM   #2
GeneralTJWillys
First, are you sure it's coming from the rear end? In the center section area? Second, is this a stick or automatic?
When you say "back and forth slop in the rear end", can you be more specific? Do you mean the pinion shaft can be moved back and forth? Because the pinion should not move at all.
No, the slop on the T-case output shaft should not be there at all either. This and the pinion shaft should only have rotational movement.
These are signs of serious problems if I'm interpreting correctly.
JEEP.........Gecko of the automotive world!!
Constitutional, Independent, Conservative leaning, gun toting crazy American patriot!! WATCH OUT!!
GeneralTJWillys is offline   Reply With Quote
Old 05-10-2009, 10:31 PM   #3
WHITEXJ7
kinda sounds like what mine was doing when ya left off the gas, more of a grindig noise, i put on my s.y.e. and it eliminated the vibes completly!
2000 Cherokee Classic 4.0L Auto NP231 HP D30 / C 8.25 3.5" TC w/ 2" Blocks 31X10.50X15 BFG/AT RE HACK 'n' TAP CV DRIVESHAFT Surco Roof Rack JK Rubicon Shocks
______ooooo
/__l_l_,\____\,___
l_---l_l__l---|llllll|
_.(o)_)__(o)_)--o-)_)
Originally Posted by FairlanePhil View Post
These days all I dream about is waiting in line at AutoZone
Originally Posted by MrSimon View Post
XJs are the Brett Favres of vehicles. They ain't perfect, they ain't glamorous, but they are tough as nails and keep on truck'n for years and years.
WHITEXJ7 is offline   Reply With Quote
Old 05-10-2009, 11:06 PM   #4
Redrider341
i have the same sound from the rear end mine is all stock and its at all speeds when i left off hit brakes and accel and i narrowed to my LR drum is out of adjustment im 99% on it and im begining my process of my 3in lift this week and will see if i can stop the noise.....
SILVER JEEP CLUB MEMBER #107
[l_|__\_i__\,__
l--___--[=lllllll=]
()_)' '()_)---)_)
Redrider341 is offline   Reply With Quote
Old 05-11-2009, 07:21 AM   #5
portcityXJ
1995 XJ Cherokee
u bolts torqued correctly?
I approve this message.
Originally Posted by EricRollerSkate View Post
Do they come in any other varieties besides crap?
portcityXJ is offline   Reply With Quote
Old 05-11-2009, 09:32 AM   #6
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Check the Ujoints at the driveshaft and look for contact marks on the pinion yokes.
If you are running 3" lift blocks, that could also be part of the problem when gassing it.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Glock Forum
