00 Cherokee Cylinder head torque specs - JeepForum.com
post #1 of 5 Old 11-02-2009, 08:28 AM Thread Starter
theducksguts
I am putting in a new head. I have the FSM for a 99 and am wondering if the torque specs are the same.
For the 99 4.0 it states - after the initial torque sequence.
Bolts 1 through 10 to 149 Nm (110 ft. lbs.)
torque.
Bolt 11 to 13 Nm (100 ft. lbs.) torque.
Bolts 12 through 14 to 149 Nm (110 ft. lbs.)
torque.
Can anyone with a 2000 XJ FSM tell me if it is the same spec?
Check out my
theducksguts is offline
post #2 of 5 Old 11-02-2009, 09:00 AM
Kettles
Here is it from the the 00 manual. (for w/e reason my 01 has the 00 in it, I guess they must be the same)
Tighten all bolts in sequence (1 through 14)
to 30 Nm (22 ft. lbs.) torque.
(b) Tighten all bolts in sequence (1 through 14)
to 61 Nm (45 ft. lbs.) torque.
(c) Check all bolts to verify they are set to 61
(d) Tighten bolts in sequence:
† Bolts 1 through 10 to 149 Nm (110 ft. lbs.)
torque.
† Bolt 11 to 135 Nm (100 ft. lbs.) torque.
† Bolts 12 through 14 to 149 Nm (110 ft. lbs.)
torque.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #3 of 5 Old 11-02-2009, 09:00 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
From the 2000 FSM
CAUTION: During the final tightening sequence,
bolt No.11 will be tightened to a lower torque than
the rest of the bolts. DO NOT overtighten bolt
No.11.
(a) Tighten all bolts in sequence (1 through 14)
torque.
torque.
(e) Check all bolts in sequence to verify the correct
torque.
(f) If not already done, clean and mark each bolt
with a dab of paint after tightening. Should you
encounter bolts which were painted in an earlier
service operation, replace them.
<-- Front of engine, bolt numbers torque sequence.
12-8-4-1-5-9-13
11-7-3-2-6-10-14
CJ7-Tim is offline
post #4 of 5 Old 11-02-2009, 09:02 AM Thread Starter
theducksguts
Thanks a bunch guys!
Check out my
post #5 of 5 Old 11-02-2009, 10:04 AM Thread Starter
theducksguts
Ha your right I did. I am using my lappy down in the garage and I was rushing. Good catch.
Check out my
Torque specs on a 2002 Grand Cherokee MicMcKee XJ Cherokee Technical Forum 2 07-24-2009 08:20 PM
Cherokee Lift Torque Specs HankyDanky XJ Cherokee Technical Forum 3 03-16-2009 06:00 PM
Torque Specs on Head Bolts ineffablelove XJ Cherokee Technical Forum 6 08-30-2008 10:27 AM
4.0 torque specs for head! rivers edge XJ Cherokee Technical Forum 2 04-16-2007 04:40 PM
torque specs for the head bolts? 600dollarXJ XJ Cherokee Technical Forum 1 12-03-2005 06:42 PM
