TJ HUGE LIST! Dodge Scout - JeepForum.com
post #1 of 6 Old 06-02-2008, 05:40 PM Thread Starter
mikeyapproved
Parting 98 TJ and some Dodge stuff…. in Prince George BC
43000 kl’s on this stuff unless otherwise posted…..
Grey interior parts, white body parts
TJ Frame. Setup for Teraflex style LCG Pro 6” lift. This includes:
Flat skid with integral lower front and rear 4 link brackets. (NO TRACK BARS!) This has had the mounts changed from the wimpy “nutsert” style inserts for the skidplate mount, to Thru bolts and tubing inserted in the frame both for the 3 verticle bolts and 1 additional side bolt. Very strong!
Custom 2” body lift ( all weld on mounts were relocated 2” up on the frame)
Custom 2” Fuel tank lift (same as above)
4 new ford upper shock mounts (not installed)
New 6” rear coil springs
New 9” lift front coil springs, with custom front upper mounts to keep the lift at 6”
Summit Machine Jimmy Joints and bushings for all 8 links
Dana 44 HP custom front axle with 3” tubes, New O/H bearing kit, Yukon 5:13 gearset, new ujoints, brakes etc. This axle uses waggy inner axles, TJ dana 30 outers complete and comes with a new Teraflex High Steer kit. (knuckle, tierod assy and draglink) This axle needs the C’s welded on once you determine pinion and caster angle required, plus assembly after welding. The coil spring mounts and the 4 link brackets are welded on.
Ford 8.8 rear (98 explorer) with new disc pads and park shoes, new O/H bearing kit, brake cables, Yukon 5:13 gearset, stock posi, new seals etc and the 4 link brackets welded to the housing. Needs final assembly.
New 4” drop steering pitman arm
This frame is setup for a 4cyl now that is 8” ahead of stock and 3” up from stock. This gives the flat skid and a longer rear driveshaft. A stock 6 cyl fan shroud can then be used with the rad in the stock location.
Note all stock suspension brackets have been removed from this frame
3000.00 Less than ½ price for what is listed! I would rather sell this frame/axle setup as a package deal
Tub (bare) Includes rear High mount 7” flares and radiused rear wheel wells and LED lights 1750.00 NO RUST
New CAMO softop with fabric ½ door tops, tinted windows for a TJ Includes TJ stock mounting hardware, bows etc. THIS TOP LOOKS GREAT!! Have pics!
575.00
Custom Fiberglass hood 100.00 (fenders built in) This is a prototype without gelcoat and is rough….
Tailgate complete 150.00
Rollcage assembly with sound bar and black cover (stock) 195.00
Steer colume and both airbags and keys 275.00
4 cyl engine computer 50.00
Airbag computer 50.00
Rear tumble seat with mounts and belts 150.00
Front buckets W/O mounts 50.00 (note these have 150 000 kl’s on them)
Seat belts frt 20.00 (note these have 150 000 kl’s on them) SOLD
Transfercase NP 231 21 spline 225.00
Transfercase NP231 23 spline 1994 YJ 145000 KL’s 175.00
AX 15 1994 145000 Kl’s 175.00
Dana 35 with 4:10 gears complete, less side and spider gears 155.00
Custom Rockers with side tubes 295.00
1 L/H front flare black with light 15.00
Engine harness, custom mod to mount the Power control box and Computer behind R/H dash ( airbag delete) 4 cyl 5 speed 100.00
Dash (less gauge cluster) Includes all switches etc. 75.00
Gauge cluster 100.00
Stock skidplate 50.00
Dana 30 yoke 10.00
Dana 30 cover 5.00
Dana 30 (TJ) inner axles 25.00 each
Rear driveshaft ( note this is 8” longer than stock) 75.00
Front driveshaft (note this is 8” shorter than stock) 100.00
Transfercase shifter 15.00
Stock radio cassette 10.00
Custom Hoop style front bumper with receiver mount 100.00
Custom steel Tube roofrack and mounts Very tough ( note ONLY fits with softop! Not hardtop) 650.00
Rear “hidden Hitch” # 90078 (small receiver size) 50.00
Rear swaybar 10.00
Rear inner fender shields 5.00
P/S pump for a 4cyl 50.00
Console (modified in the shifter area…. ) grey 10.00 SOLD
Stock springs 20.00 set
Stock trailing arms 5.00 each
Fueltank with mount and pump 125.00
Then I also have some Dana 44 stuff
Scout front Dana 44 housing only, not knuckles or guts 30.00 mileage unknown?
Scout Dana 44 rear with 3.92 gears 100.00 mileage unknown?
Waggy Dana 44 rear offset housing 3:54 gears 100.00 mileage unknown?
Older Dana 44 rear Jeep?? 75.00 5x5.5 bolt pattern mileage unknown?
YJ Roll bar older CJ style 50.00 SOLD
Dodge NV3500 core (1996) 150.00 180000 Kl’s?
1996 Dodge 1500 4x4 axles, 100.00 each 180000 Kl’s?
1996 Dodge 1500 front coil springs 20.00 set 180000 Kl’s?
Transfercase NP231HD 23 spline input 32 spline output (Dodge) 250.00 180000 Kl’s?
Dodge Fulltime front axle ½ ton 100.00 mileage unknown?
Whew!
Ok, offers??
Thanks Mike.
Please email me if you are interested in anything listed?
I can zip pics of anything……
Paypal or cash please
Shipping is whatever works the best for you…. But it may take some time, depending on what I need to take apart….
ijeepbc@yahoo.ca
mikeyapproved is offline
post #2 of 6 Old 06-04-2008, 10:28 PM
jboy416
Wrangler
jboy416's Avatar
hey man i am up here from vancouver island planting for the summer. i have sunday off and would love to come check out some parts... mostly your custom rockers. let me know if this works for you.
jboy416 is offline
post #3 of 6 Old 06-04-2008, 10:37 PM Thread Starter
mikeyapproved
Sunday??
Hi.
Give me a call after 3:00 PM Sunday afternoon.......
Thanks, Mike.
1 250 613 5335
ijeepbc@yahoo.ca
post #4 of 6 Old 06-04-2008, 10:45 PM
jboy416
Wrangler
jboy416's Avatar
sounds good. i am assuming we will get those days off...it all depends on production. but so far thats the day off we are supposed to have. talk to you soon
jboy416 is offline
post #5 of 6 Old 06-05-2008, 11:11 AM
Y2KWRANGLER
Hey jboy416 you be willing to bring back the front tj axle shafts for me? I can paypal for em. Running 35's now and am going to need all the spares I can get my hands on. Let me know
If it Breaks it needed replacing anyways!
Canadian Jeep Club Member#1
Red Jeep Club Member #390
bcjeep club.ca
Y2KWRANGLER is offline
post #6 of 6 Old 06-05-2008, 10:09 PM
jboy416
Wrangler
jboy416's Avatar
absolutly...if you pay mikeyapproved and let him know i will pick them up for you. i won't be home till around aug 4-5 if thats fine with you. but i will def bring back whatever you want.
jboy416 is offline
Dutchess Dodge Service Team Are Crooks bsteeves86 North East USA 5 12-10-2009 06:40 PM
HUGE South East/North East Regional Meet Uwharrie NF Nov 6-8 eagleswarrior North Carolina Jeep Forum 52 11-08-2009 07:38 PM
ARIZONA Meet and Greet + Cub Scout Fund Raiser Fett Arizona Jeep Forum 2 04-02-2009 10:29 AM
All Chrysler-Dodge-Jeep Car Show, 1980 and newer cnypt North East USA 11 03-30-2009 12:55 PM
