Doorless in Ontario? - JeepForum.com
post #1 of 10 Old 04-17-2012, 08:15 AM Thread Starter
5foot19
2016 JK Wrangler
Anyone happen to know if it is legal to run doorless in Ontario with just the one rear view mirror on the windshield? I've tried searching but have come up with conflicting information and my google skills are not what they used to be
5foot19 is offline
post #2 of 10 Old 04-18-2012, 09:27 AM
Mopar Fan
From the HTA:
66. (1) Every motor vehicle other than a motorcycle shall be equipped with,
(b) a mirror or mirrors securely attached to the vehicle and placed in such a position as to afford the driver a clearly reflected view of the roadway in the rear, or of any vehicle approaching from the rear.
Mopar Fan is offline
post #3 of 10 Old 04-18-2012, 08:36 PM
hvymetal
Doorless in Ontario!
I spend all summer doorless and I have driven by many police cars. Never an issue.
The issue arises when you put your windshield down and take to the city streets. At that point you have no mirrors or windshield wipers. Both are against by-law.
I don't often do windshield down but when I do I've prepared what I would say to the officer if I were pulled over....I'd simply point out that the no mirrors and no windshield wipers by-laws exist to keep vehicles in a state of repair eg. not driving around in the rain or snow with broken wipers or mirrors. The spirit of the by-law is not at all captured in a Jeep driving stripped out under the clear summer skies.
hvymetal is offline
post #4 of 10 Old 04-25-2012, 10:37 PM
Estenlobo
got stopped once a couple years ago on the 400 by OPP - no ticket, he just said to put mirrors on
Estenlobo is offline
post #5 of 10 Old 04-28-2012, 07:10 PM
Luck881
Luck881's Avatar
I confirmed what Mopar fan said with Upper Ottawa Valley OPP about 7 years ago. They told me as long as the view through the center mirror wasn't obstructed by a tire carrier or something that it was fine. Never had an issue up here with them, Pembroke City or the MP's. As long as Ottawa police don't have a hate on for Jeeps, you should be fine.
And I have been pulled over for lots of rediculous s#!t while doorless and lack of door mirrors has never been mentioned.
Ian
'05 TJ SE, 2.4L, 6 Spd, 2(+)" Procomp Lift, 33" GY Duratracs
'09 Ram QC SLT
Luck881 is offline
post #6 of 10 Old 04-30-2012, 04:34 AM Thread Starter
5foot19
2016 JK Wrangler
awesome guys. Thank you very much!
5foot19 is offline
post #7 of 10 Old 10-27-2012, 08:04 AM
Madweasel
good to know!
Madweasel is offline
post #8 of 10 Old 11-18-2012, 02:42 PM
Wavedatya
2010 JK Wrangler
No issues here either. I drive all summer doorless. I have my mirrors permanently mounted with relocation brackets and the filler plate in the door. I threw out the stock mirror assembly.
FYI the mirrors mounted with doors on though the passenger side is useless. Can't even see it. It's just there for decoration when doors on. But doors off they work great.
Law states 2 mirrors. You can have rear view and one side. Pretty sure anyways
OF4WD member #7523. Durham 4x4 member.
Wavedatya is offline
post #9 of 10 Old 11-28-2012, 06:20 PM
demonz0
Didn't run with the doors off that much but when i did all I had was the rear view. I have this thing called a neck that I can rotate
demonz0 is offline
post #10 of 10 Old 02-13-2013, 10:20 PM
fang_x
Ive been to ontario with my jeep from quebec, doorless havent had any problems with local law enforcement around the Ottawa area.
In quebec by law you need two rear view facing mirrors, so that can be a driver side mirror, plus your interior mirror.
To play it safe, get yourself a set of bicycle mirrors, the kind with the clamp for a handle bar, remove the clamp and just insert the threaded part into your doors hinge with a nut
'98 TJ Manual -2.5" rcx long arm on 31
'99 Xj, Stock on 30"
'86 Monte Carlo 357 stroker. 450hp.
fang_x is offline
Anyone in SW Ontario arbby Canada 208 05-07-2014 06:37 AM
Any ORV parks in Ontario? Hurley91 Canada 14 02-15-2013 07:38 PM
Hello from Southern Ontario! Staangette Canada 2 01-26-2012 08:12 PM
in desperate need of mud in K-W ontario ozdifarian Canada 0 08-30-2010 06:25 PM
anyone in NW Ontario? RY97TJ Canada 0 10-25-2008 11:36 AM
