Yet another tire question - JeepForum.com
post #1 of 8 Old 03-12-2013, 08:25 PM Thread Starter
tj98
I'm throwing this in this section because it is the closest to my situation.
I just took over responsibility for maintaining our church van, a 2003 Chevy Express 2500 fifteen passenger van. The church bought it used about a year ago and someone got some "good cheap" new tires for it. We have about 6K miles on them.
I had someone take it in for maintenance and a thorough inspection by the local Chevy dealer, not a typical stealership, decent guys I went to school with. Got the report back with a warning that the new tires are not safe for the vehicle!
The techs acknowledged they were good tires, just not the right tires for the van. The tires on it are a 24575R16 "Standard Load" tire. Specs for the van call for a LT24575R16 E tire. From what I can determine a Standard Load tire is a four ply tire while the E designation means it should have a 10 ply tire.
I'm going to have to explain this to non car people who just want tires that are round and roll. The "Max Load" rating on the tires is 2403 lbs at 44 psi which works out to 9612 lbs. That's more than the gross weight of 8600 lbs of the van. How do I explain that doesn't relate to the load carrying ability of the tire at normal pressures? The recommended pressure on the door are 50 psi front and 80 psi rear, far more than these tires are capable of holding.
I'm also calling an inspector tomorrow to see if they would even pass it knowing the tire limitation. It passed once and is due again.
I'm already known as the guy that overbuilds everything. So I need to be able to explain this is a real problem and not just me wanting to prove a point. Any non-technical explanations would be great.
Thank you!
98 TJ - Sold
99 TJ - Mine
10 JKU - Sold
14 JK Unlimited - Wife's
tj98 is offline
post #2 of 8 Old 03-13-2013, 10:09 PM
alittleoff
Ask them if they remember the difficulties the Ford Exploder/Firestone tires had.
Steve
All slow and no show
alittleoff is offline
post #3 of 8 Old 03-14-2013, 01:46 AM
MPond
I would recommend a simple explanation in terms they can relate to, such as this:
The current 4-ply "car" tires are not rated for a van that would often get loaded down with 15 passengers and all their gear; it really should have the proper 10-ply "truck" tires.
The cost of 4 new tires is relatively low, compared to the risk of a blowout at highway speeds with 15 people onboard.
Just my $0.02 - feel free to ignore.
2006 Black Unlimited 6-speed, Rubicon Express 5.5" Long Arm Kit
MPond is offline
post #4 of 8 Old 03-14-2013, 11:16 AM Thread Starter
tj98
Quick update, I found out last night that the church had requested and were told they were 10 ply tires. All agreed we need to correct before taking the van out again.
So, I will be calling the tire shop to find out what happened. Tires are clearly marked "standard load". Will see if they wont make it right.
98 TJ - Sold
99 TJ - Mine
10 JKU - Sold
tj98 is offline
post #5 of 8 Old 03-14-2013, 12:06 PM
MPond
Hopefully they'll do the right thing.
MPond is offline
post #6 of 8 Old 03-15-2013, 05:58 PM Thread Starter
tj98
Well they didn't make it right. Owner told me the non car person that brought it in told them to put what was on it back on it so they did. He even acknowledged they weren't right but wouldn't do anything.
10 ply tires on order from local Chevy dealer. They were cheaper than wally world on the same tires and threw in an alignment.
98 TJ - Sold
99 TJ - Mine
10 JKU - Sold
tj98 is offline
post #7 of 8 Old 03-24-2013, 08:29 PM
Jon-joN
Btw in my state, VA, you can get a ticket for underinflated tires. So if the door sticker says 60 and you only have 45, there's a moving violation ticket
Jon-joN is offline
post #8 of 8 Old 03-26-2013, 09:03 PM Thread Starter
tj98
Tires are on, ordered @ 445 on Friday and they called @ 900 Monday that they were in.
I will keep them at spec pressure, 55 front 80 rear iirc. That and using torque wrench on lug nuts are habits of mine.
Thanks.
98 TJ - Sold
99 TJ - Mine
10 JKU - Sold
tj98 is offline
