will this set up work? - JeepForum.com
post #1 of 6 Old 01-18-2010, 09:32 AM Thread Starter
jdub36
I have a 2006 toyota tundra double cab. I have a 16ft utility trailer with brakes. I am wanting to use this to pull my 01 tj about 5 hours for a hunting trip. I live in central texas so terrain is pretty flat. I hoping to make this truck work since it is paid for and even though i like the new bigger tundra i do not like the payment that comes with them.
thanks,
Josh
jdub36 is offline
post #2 of 6 Old 01-18-2010, 10:45 AM
shrewd
You should be fine as your max towing capacity is 6800 and I doubt your jeep/trailer combo pushes more than 6000. Keep overdrive off. You may also want to look into an auxiliary transmission cooler if you have an auto. They're typically ~$100 or so installed at uhaul. Cheap insurance.
I used to flat-tow my 3280 lbs of jeep up over the rockies in a 99 4runner with that weak 6-banger, no problems.
My D35 grenaded at 65mph, fun times.
shrewd is offline
post #3 of 6 Old 01-18-2010, 10:47 AM
ZJ5point2GCL
do you have a v8?
ZJ5point2GCL is offline
post #4 of 6 Old 01-18-2010, 10:49 AM
shrewd
Originally Posted by ZJ5point2GCL View Post
do you have a v8?
All double cabs come with v8's if I remember correctly.
shrewd is offline
post #5 of 6 Old 01-18-2010, 11:01 AM Thread Starter
jdub36
yes the v8 that they used in 06, i think it is smaller than the v8 they are using in the newer tundras but it does fine in the smaller body style that i have. I have not towed anything as heavy as the jeep with my tundra(just atv's and a boat) I could not even tell i had the trailer behind me when loaded with that stuff but the jeep it alot heavier than those things so i was not sure if i had enough truck.
jw
jdub36 is offline
post #6 of 6 Old 05-16-2012, 09:08 PM
aspjeepguy
2016 JK Wrangler
How did this ever work out for you?
I just picked up the same truck as you described?
aspjeepguy is offline
What PSU will work?! CoriolisSTORM General Discussion 5 10-28-2008 07:45 PM
Fab work Yule16MET General Discussion 3 06-28-2006 07:04 PM
Does This Really Work? C2U5H General Discussion 12 08-19-2005 07:39 PM
P/T work JKNIPE2000 General Discussion 31 07-22-2005 08:18 AM
my work PDshooter General Discussion 10 07-15-2004 11:37 AM
