Will a 6'4" Jeep fit in a 6'6" enclosed trailer? - Page 2 - JeepForum.com
post #16 of 19 Old 01-11-2013, 04:45 PM
nygiants
You could find out the height of the ramps or door to the trailer and then jack up your front end from there. so then you'll know how high your front will be off the ground and if it raises your jeep too high
nygiants is offline
post #17 of 19 Old 01-17-2013, 11:52 PM
bruteboy
on my cargo trailer,the ceiling height is 6'6" but the door opening is only 6'.
check the door opening height to know if it will fit.
bruteboy is offline
post #18 of 19 Old 01-18-2013, 12:01 AM
sjones26573
Obviously this is quite old but I just wanted to verify that MPond is in fact absolutely correct and wilson is wrong. Anything behind the vertical plane off of the pivot point, i.e. front axle, will be lower than that point until both tires are within the trailer. The rear will never be higher than the intersection of the horizontal plane of the roof line and the vertical plane of the front axle. However, had he been loading a perfect rectangle with axles, anything in front of the front axle likely would hit, which is why you don't back in.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #19 of 19 Old 01-18-2013, 05:44 AM
MPond
Thanks!
2006 Black Unlimited 6-speed, Rubicon Express 5.5" Long Arm Kit
MPond is offline
