Weight Distribution Set UP - JeepForum.com
post #1 of 9 Old 12-24-2013, 07:41 AM Thread Starter
Tiburon
2011 WK
I posted this in the WK2 forum and received zero responses. Thought I might try it here.
I have a new to me 2011 WK2 5.7 Hemi Overland with full air suspension. Looking for suggestions on proper procedures for setting up a Weight Distribution system for towing a 1964 Airstream Bambi II travel trailer. It has a weight of about 2500 lbs loaded. Hitch weight is under 350 lbs.
Just Happy To Be Alive!
Tiburon is offline
post #2 of 9 Old 12-24-2013, 07:57 AM
xjtrailrider
I run a Valley weight distributing hitch with my 19' car trailer and my 09 Hemi XK. Tongue load is up there with a 4klbs pig of a off-road XJ on it. 7k total on the trailer. I also use the stabilizing attachment.
Set the load bars when the vehicle is sitting normal height and the trailer is slightly nose up. I use the trailer jack to get it where I want it. Of course you need to adjust the hitch to match first.
Most trailer dealers will set the hitch up for you for free if you buy the hitch from them or for a small fee if you didn't
xjtrailrider is offline
post #3 of 9 Old 12-24-2013, 12:23 PM
smccollamjr
Checkout http://www.rv.net/forum/
'00 TJ/4.0/NV3550/D30(Aussie)/D44(LSD)/3.73s/1"MML/1.25"BL/OME Springs/UCF TT/33s
Build Thread:
SOLD-'96 XJ, Build Thread:
smccollamjr is offline
post #4 of 9 Old 12-24-2013, 12:55 PM Thread Starter
Tiburon
2011 WK
Originally Posted by smccollamjr View Post
Looked and could not find info. Did you have a specific thread in mind?
Tiburon is offline
post #5 of 9 Old 12-24-2013, 01:48 PM
xjtrailrider
post #6 of 9 Old 12-24-2013, 03:04 PM
smccollamjr
Do a search. There are lots of threads about weight distribution set ups.
Build Thread:
post #7 of 9 Old 12-24-2013, 03:08 PM Thread Starter
Tiburon
2011 WK
Thank you for the suggestions but I guess I did not make my self clear. My question is what do I do with the air suspension? I have used the Andersen WD system with a couple of different tow vehicles, so no problem with the actual set up procedure. I am asking what do I do with the air suspension. It levels but does not actually move any weight from one end to the other so a WD system is still necessary for proper WD. Should I deactivate the suspension during set up? If so should I am assume that the height should be set to "normal" and than turn it back on after properly setting up the WD system?
Tiburon is offline
post #8 of 9 Old 12-24-2013, 03:15 PM Thread Starter
Tiburon
2011 WK
Thank you for that suggestion. I know enough to try that before bothering you.
Tiburon is offline
post #9 of 9 Old 12-25-2013, 06:59 PM Thread Starter
Tiburon
2011 WK
This was some recommendations that I received on another forum from a member with actual experience with my set up.
"I will repeat the Air Suspension information for the Grand Cherokee. Mine is a 2012 Overland. I suspect this information will also work for the newer ones, and for the half ton RAM trucks which are now using Air Suspension. I caution readers who are not familiar with this system that it is NOT the same as other air suspension systems you may have seen in the past. It is not a helper system, but replaces the springs and shocks totally and is integrated fully with the other computer driven systems in the GC.
First: find a dead level spot big enough for your TV and Trailer. Unhook the trailer, move the TV away a few feet. The dead level spot is critical as the Air Suspension system automatically tries to "look pretty" by adjusting the individual wheels to compensate for varying irregularity in the level of the parking spot. So, you need a level parking spot to start with. Let the rig idle for a few minutes allowing it to set it's level.
Second: Turn the Air Suspension system off (on the GC, press the up and down buttons at the same time for 10 seconds). Measure the fender heights above the ground and record. Back up to the trailer, raise the tongue and re couple, carefully dropping the tongue on the ball
Third: measure the fender well drop, then use your weight distribution hitch system to bring the fender measurements back to the original measurements, or as close as possible.
Forth: Drive away. The Air Suspension will automatically turn back on by itself in a short time.
Now, I would also advise checking your system by doing the same thing at a scale, only this time you can do before and after weights on all axels. I actually started by doing this at a closed Idaho Department of Transportation scale, which they leave on all the time and you can play to your heart's content. Once I was comfortable with the weights, I found that you can also rely on the fender measurement system to work quite well, that is the settings work out about the same, at least with my rig.
The Air Suspension system on the GC will hold the rear end of the rig high and level all by itself, even without a WD hitch system, but trust me, you will easily overload your rear axle and under load the front, if you don't follow the above system and don't use a WD hitch. It will look level and hold level, but that does not mean it is right and that the axels are not overloaded in the rear and underloaded in the front. Scale measurements will show that to be true.
I hope that helps some more.
For the record, I have done this with both an old round bar WD hitch setup and the Andersen. I use the Andersen now almost exclusively with excellent results. My tongue weights are in the 700# range on both of my 20' trailers."
Tiburon is offline
