Weight & Distribution Hitch ? - JeepForum.com
post #1 of 7 Old 09-13-2006, 01:56 PM Thread Starter
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
Anyone using one? Tips for installing one? What exactly do they do? Have heard they reduce sway, help with braking, and many other things. If you have one... which one, price, did you install it or have some one install it... Thanks.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #2 of 7 Old 09-13-2006, 05:19 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
I have one...bought it used for $125...can't remember the brand, but I'll go look after it quits raining...
between the WD hitch and the dually, mine tows awesome!!
the purpose of them is to distribute the weight up to the FRONT tires of the tow rig...instead of leaving it all on the rear...they have additional attachments that are more for sway control...
mine has to clamps that clamped onto the trailer...I just had to notch the frame a bit...
then, it has to arms that you hook up once the trailer is connected...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #3 of 7 Old 09-13-2006, 05:31 PM Thread Starter
JeepRocks86
ok gotcha... but how exactly does it work? anyone know? Is there any brand to stay away from? any brands that are the best? I've seen them from anywhere from 250-500+
What's the difference between the Trunnion Style Weight Distribution, the Round Bar Weight Distribution, or any other ones? just the type of tubeing>
For Sale:
post #4 of 7 Old 09-13-2006, 05:43 PM Thread Starter
JeepRocks86
Also I take it that the sway control arm is the arm that connects to the smaller ball (usually on the passengerside) and is another add on? trying to get as much info as possible.
For Sale:
post #5 of 7 Old 09-13-2006, 09:31 PM
drewman141
Gas Guzzler
drewman141's Avatar
1994 ZJ
Some good information here http://mrtruck.net/wdh.htm That's where I got mine from I'll let you know how it works after this weekend.
[SIZE="1"]2008 WK Overland HEMI - Modern Blue Pearlcoat
Fully loaded with slush mats of course.
MUST GO! 1994 Limited ZJ 5.2L V8 - Light Driftwood Satin Glow
It's a 94 5.2L Limited - trxus 33's on 15x7 steelies, 4.56s w/ front OX and rear trutrac, NP242 swap, novak shift kit, Kevin's ultimate 4.5" lift + ACOS, ARB front bumper w/warn M8000, rear tomkin machine bumper w/ tire carrier, kevin's hardore railz, kevin's ultimate tc skid, kevin's trackbar conversion, rusty's gas skid, flexalite efan, Kolak's performance ignition and brake upgrades. ViAir OBA, custom storage/sub box and I'm sure there's a bunch of other things I'm missing. Everything is a little over 3 years old with less than 10K miles. Looking to get around $4k.
drewman141 is offline
post #6 of 7 Old 09-17-2006, 08:05 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
some more info here:
http://www.etrailer.com/faq/aboutwd.asp
mine is a Quality S model with a max of 1,000 lb tongue weight...and is the two bar trunion style setup...that bolts on...
bought it used, so I don't really know the part number...
basic premise is that it uses the leverage of the long arms (like on a wheelbarrow) to put 1/3 of the weight on the front tires of the tow rig, 1/3 on the trailer tires, and 1/3 on the hitch/rear tires of the tow rig...
Greg
post #7 of 7 Old 09-18-2006, 03:00 AM
jebdrup
jebdrup's Avatar
I have an equalizer (WDH 10,000 lbs model). I have never used one before and all I can say it was worth every penny. I towed with it for about 2300 miles and the trailer moved with the vehicle and no swaying. I tow with a Ford Excursion and a 16' foot trailer. Tow rig, trailer, and Jeep weighed about 15,000 lbs. It was easy to install. I like the Equalizer brand because it is both a WD and sway control. Just $.02.
http://www.equalizerhitch.com/
89' YJ, AMC 304, TF999, D300 (4:1), 60/14, 38.5s (For Now)
jebdrup is offline
where 2 get heavy duty hitch (class 4/500 lb. tongue weight) for an 87 wrangler YJ? submaniac Trailers & Towing 7 08-30-2015 08:00 PM
Anyone work at a Wal-Mart Distribution Center? SteelBlueTJ General Discussion 8 06-17-2009 05:17 PM
The Distribution of Wealth in America ScotZ General Discussion 20 09-19-2008 04:26 PM
What type of weight distributing hitch? JeepRocks86 Trailers & Towing 5 06-25-2007 05:27 PM
wheel weight EaglesSJ General Discussion 1 08-06-2005 10:25 AM
