Water Logged Trailer deck?? - JeepForum.com
post #1 of 7 Old 10-15-2013, 02:22 PM Thread Starter
RowJ
I just had cause to re-weigh my truck, Jeep & Trailer.
Identical setup 2 weeks ago was 13,800 lbs total
Yesterday, weighed 600 lbs more?????
Same scales (state scales at a Tx truck weigh station)
Only change between two weigh-ins is I put the soft top back on and.....
heavy rain the days before(trailer outside) and light drizzle during second weighing.
Any ideas??
RJ
RowJ is offline
post #2 of 7 Old 10-15-2013, 04:06 PM
Indy
Indy's Avatar
The deck would have had to absorb 72 gallons of water to gain 600 pounds. That's a lot of water. Odds are there is a margin of error in the scale coupled with some water weight.
I'm the only gay eskimo.
Indy is offline
post #3 of 7 Old 10-15-2013, 05:18 PM
N128CG
What about fuel?
N128CG is offline
post #4 of 7 Old 10-15-2013, 08:33 PM
thantos858
1974 CJ5
State certified scales aren't off that much unless they are broken which is likely. The one I use at the dump was off by 20lbs from the DOT scales. More than likely it was the scales. Doubt you can put 600lbs with a soft top, fuel and a bit of rain. gas weighs only 6.073 lb/gallon soft top is probably 100-200lb.
thantos858 is offline
post #5 of 7 Old 10-16-2013, 09:21 AM Thread Starter
RowJ
The deck would have had to absorb 72 gallons of water to gain 600 pounds.....
Yup.... I figured 75 gal. Just not possible on a treated deck, no matter how old.
Both were full fuel!
Soft top is probably not even 50 lbs.
Maybe some water on scale surface would affect readout?
It's a mystery! Guess I need a third weigh-in to see.
RJ
RowJ is offline
post #6 of 7 Old 10-16-2013, 10:57 AM
wilson1010
DOT is + or - 1%, by DOT Regulation.
Most scales are less accurate at the low end of their weight range given fixed errors with variable weight to compare. In other words, a postage scale that is off 1/100 oz. because of friction is only 99% accurate when weighing a letter weiging an oz. And, when a 3 pound pagage is on there it goes up to 99.9%. So, if a truck scale has to be 1% accurate when weighing a truck, by regulation, it might be off 800 pounds. Certainly, one would not expect the 1% to apply if one put a 600 pound motorcycle on the scale.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #7 of 7 Old 10-19-2013, 11:30 AM Thread Starter
RowJ
Originally Posted by wilson1010 View Post
.......Most scales are less accurate at the low end of their weight range....
Good point, and yet..... I have weighed my Dodge/Cummins pickup (by itself) a few times on two different State scales and with me and full fuel it always come out +/-50 lbs of 7700 lbs.
RowJ is offline
