UHMV for utility trailer sides and bottom - JeepForum.com
post #1 of 2 Old 08-27-2010, 07:59 AM Thread Starter
cc130nav
1980 CJ7
I have seen where the UHMV plastic has been used as skid plates and was wondering if anyone has seen or used it for a trailer? Am looking for a non-rust/rot solution for my 4x6 utility trailer, the largest thing that goes in the trailer is my riding lawn mower and thats only occasionally. I also realize that material is slick and was wondering how a roll on bedliner would adhere to it? Thanks in advance for the help.
cc130nav is offline
post #2 of 2 Old 08-27-2010, 04:32 PM
thantos858
1974 CJ5
I wouldn't use it for a trailer floor even if you did coat it with something it wont bond correctly to that plastic. Best thing would be to stick with a steel and just keep up with the maintenance of a trailer. You could also use a pressure treated lumber just make sure to treat the part that goes towards the ground with something and don't let mud or anything build up that will prevent it from draining water and drying out.
thantos858 is offline
Utility trailer build dylantheheeler Trailers & Towing 17 09-28-2010 09:26 PM
Weight of utility trailer? hyperrust Trailers & Towing 6 09-02-2010 08:02 AM
5x8 Utility Trailer - YJ Pulling SimonTuffGuy Trailers & Towing 21 06-02-2009 07:19 PM
Utility trailer lining? SpydermanTJ Trailers & Towing 0 03-21-2009 02:57 PM
What size utility trailer is better? victorb Trailers & Towing 4 08-15-2008 02:03 PM
