Travel Trailer Towing - JeepForum.com
Go Back JeepForum.com > General > Trailers & Towing > Travel Trailer Towing
Gibson WK HEMI 3" Catback - 5 Day Special!The ULTIMATE "Selectable" Locker System! Brough**Flash Weekend Sale** Rockridge4wd.com Only!
Unread 06-09-2015, 09:50 AM   #1
georgie2
I have a Jeep Cherokee Trailhawk with a 3.2L V6, I would like to know if anyone has towed a travel trailer with one and how smooth was the whole trip. I know it says you can tow up to 4,500 lbs.
georgie2 is offline   Reply With Quote Quick reply to this message
Unread 06-09-2015, 04:30 PM   #2
smccollamjr
Your biggest problem will probably be sway. I towed a 23' TT with my XJ several times and that was my biggest issue. A good weight distribution setup with sway control will help a lot.
'00 TJ/4.0/NV3550/D30(Aussie)/D44(LSD)/3.73s/1"MML/1.25"BL/OME Springs/UCF TT/33s
Build Thread: http://www.jeepinwv.com/forum/viewto...p?f=51&t=26137
SOLD-'96 XJ, Build Thread: http://www.jeepinwv.com/forum/viewtopic.php?f=51&t=6523
smccollamjr is offline   Reply With Quote Quick reply to this message
Unread 06-10-2015, 01:19 PM   #3
Ross
I had a 01 Grand Cherokee that had the same problem. I didn't use a weight distributing hitch or any saw control. I have since gotten a different tow vehicle.
But if you are looking of ideas on a trailer I have one like pictured below. In a period of about 5 years I had 3 different camper trailers and I have kept this one. I like it allot. it is 2400 lbs empty and plenty of room. This is just a random add I pulled of the net. My trailer is identical.
here is the layout and specs
http://www.kz-rv.com/spree-escape/E16RBT.html
and a few pics.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor.
Ross is offline   Reply With Quote Quick reply to this message
Unread 06-11-2015, 05:54 PM   #4
smccollamjr
If you don't I dealing with the tents you get a lot more living space in a hybrid. We've got a Jayco 23B and really like the room.
Unread 06-13-2015, 07:41 AM   #5
bbacus
Pulling a trailer
Keep your weight as light as possible. If possible tow the trailer that you want before you buy it. Just to see how everything works. Trailer "sway" is not a good thing. This means that your "tongue" weight is to light. Your trailer set-up has to be right also. If you do have sway, try to keep all of your heavy gear towards the front of the trailer. Sway is a dangerous thing at highway speeds. Be safe.
bbacus is offline   Reply With Quote Quick reply to this message
Unread 06-15-2015, 10:19 AM   #6
Ross
The hybrid is a nice setup. Your beds are out of the way. No more having to take up and down the dinette. You get allot more room with basically no added weight. I can tow a 16 foot trailer down the road, park it. I open a couple latches and instantly another 8 feet of room in my trailer. In about 3 minutes my 16 foot trailer is 25 feet long.
