Trailer Theft Prevention Ideas - JeepForum.com
post #1 of 20 Old 01-27-2013, 07:00 AM Thread Starter
grogie
M-F: Cell Block #4533
grogie's Avatar
I realize that anything can be defeated if someone really wants it and has the time and availability, but what are some ideas to help keep a trailer safe, both while unhooked and hooked up?
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
2013 Off-Road Trailer -
from the onslaught of young idealists.” -- Don Colacho
grogie is offline
post #2 of 20 Old 01-27-2013, 07:19 AM
PhulesAu
I use a motorcycle chain/lock combo and run it though the rim and around the axle. Won't stop a slime ball with a cutting torch, but is a major hassle to defeat.
PhulesAu is offline
post #3 of 20 Old 01-27-2013, 07:44 AM
CoastieShep
CoastieShep is offline
post #4 of 20 Old 01-27-2013, 01:08 PM Thread Starter
grogie
grogie's Avatar
Originally Posted by CoastieShep View Post
Gee thanks. I haven't learned how to use google yet.
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
grogie is offline
post #5 of 20 Old 01-27-2013, 02:17 PM
Baitis
As above, chain through wheel and around the axle if I'm not going to be around for a few days. When connected there's not much that's easy or not a pain to do except lock the coupling. My trailer has 3200# boat on it so it's not easy to move around when not hooked up.
04 GCL 4.7
Baitis is offline
post #6 of 20 Old 01-27-2013, 05:48 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
When my trailer is sitting in the yard, I use a lock on the hitch latch, and a locking ball insert. I also chain the wheels to the axle. I figure 6 locks someone will move on the construction guy down the way who just leaves stuff in front of them without blocking you from getting them at the side moving by hand.
- Chopped / Locked
- Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Rule #1 - No talking about the weather!
BeachinXJ is offline
post #7 of 20 Old 01-27-2013, 06:31 PM
PhulesAu
Never considered a Parking Boot
PhulesAu is offline
post #8 of 20 Old 01-27-2013, 07:25 PM
wilson1010
Remove a wheel and put a block under it.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #9 of 20 Old 01-28-2013, 10:54 PM
JPNCA
Remove the tongue
JPNCA is offline
post #10 of 20 Old 01-29-2013, 11:36 AM
haloperformance
1991 XJ Cherokee
Chain through the A, wrapped around a tree and locked. Ball in the tounge with the shank cut off, locked there too. My old dry rotted wheels and tires that dont hold air mounted. Basically looms abandoned in my driveway.
91 XJ: 35"s, 4:56s 5"LA lift 3"stretch, locked, skids, cage, high steer, spray paint.
98 XJ: Stock
haloperformance is offline
post #11 of 20 Old 02-08-2013, 06:17 AM
drandersoninc
drandersoninc's Avatar
I considered a number of options (locking / removing the trailer tongue, removing a wheel, parking boot, etc). But I wanted something I could deploy easy and potentially use for something else. I settled on a 'Tulsa chain' (which is almost impossible to cut given the design / strength) and a Abus 20/80 Disk Padlock (disk padlocks are extremely hard to cut as well and this one also had the reputation of not being able to be picked. Like the others, looped ot through my rim and over the axle. Since then I have also used it to secure my generator as well as my motorcycle when traveling.
drandersoninc is offline
post #12 of 20 Old 02-14-2013, 06:14 PM Thread Starter
grogie
grogie's Avatar
^Now that's what I want to hear. Obviously you have a trailer to protect.
Which Tulsa chain are you talking about?
http://www.tulsachain.com
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
grogie is offline
post #13 of 20 Old 02-15-2013, 06:25 AM
drandersoninc
I went with the Ultimate Security Chain , not the MAX: Seen here, on left
I picked up 10ft and that was a perfect size for me, any larger and the weight becomes a concern. I also got mine with the protective cover, not so much for the chain but for the holes in the room through which I attach it.
Hope that helps!
post #14 of 20 Old 02-15-2013, 09:42 AM
Airborne Lee
Airborne Lee's Avatar
Go to a trailer shop. I found a lunette ring lock for about 40 bucks. it is made from 3/8 inch plate and locks with a standard pad lock. I got an outdoor padlock to use with it.
Frankly, it would be easier to remote the lunette ring and replace it with another one than it would be to cut my lock off.
My M416 rebuilt military trailer still has the hand parking break on it. I can padlock it also.
Ya aint gettin my trailer!!!
'16 JKU Rubicon, Tan, RR Front Bumper, 9500i, Atlas Rear w/Tire Carrier M416 Trailer
Airborne Lee is offline
post #15 of 20 Old 04-01-2013, 07:50 PM
bigwahini
While unhooked, take off all lug nuts on one side. Can you see the look on a thiefs face when he has a trailer with one wheel on it attached to his truck while sitting in your driveway? Priceless.
ifyoubegintothinkyou'relosingcontrol...it'salready gone
bigwahini is offline
