Quantcast Trailer Lights not working - JeepForum.com
Truck-Lite 7" Round Headlamp Giveaway! - Drive OffRoad Gift Certificate Contest!
Go Back JeepForum.com > General > Tow Rigs & Towing > Trailer Lights not working
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSwag Off Road BIG-HIT TJ-YJ Rear BumperNEW Fawkes modular recovery & bull bar mounts for WJs.
Unread 11-10-2006, 06:02 PM   #1
gurab
I have a 2005 grande cherokee limited and the trailer lights are not getting power? Is there a fuse that might have been blown that could cause this problem? THe lights on the vehicle work fine.
gurab is offline   Reply With Quote
Unread 11-11-2006, 07:31 AM   #2
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
Have you checked the harness with a multimeter?
Kyle - I tag stuff®
2000 Jeep XJ - Chopped / Locked
1997 Jeep XJ - Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Join the XJ Owners Club | Download the iMarn® iPhone App!
SIRA 4x4 Offroad Association
Rule #1 - No talking about the weather!
Homepage | Jeepspace Group|Twitter!|Facebook
BeachinXJ is offline   Reply With Quote
Unread 12-23-2006, 08:17 PM   #3
Ole Yeller
2010 JK Wrangler
Is the trailer light hookup from the factory on your Jeep? If so, a 05 ought be under warranty. If not factory, did you buy the factory harness? The d#@m factory harness for about $60?
2007 Patriot Limited
2006 Unlimited Rubicon
2006 Commander
2000 TJ Sport
My previous Jeeps
1992 Wrangler S (Ole Yeller)
1985 Cherokee Pioneer
1989 Cherokee Laredo
1995 Cherokee Country
1996 Cherokee Country
1996 Grand Cherokee Laredo
Ole Yeller is offline   Reply With Quote
Unread 12-25-2006, 04:48 AM   #4
flawrangler
On newer vehicles with a "towing package" there is normaly a fuse for running lights, and for each brake/turn.
flawrangler is offline   Reply With Quote
Unread 12-26-2006, 03:36 PM   #5
pendleton
I've been here before. I've left with nothing working and arriving with full functioning lights. Here are some common issues I've found. Your trailer is grounded from the connection between your hitch and ball. Make sure the trailer is actually hooked up. You can't check the lights by just backing up close and plugging the lights in. If the trailer is hooked onto the Jeep and still nothing is working, try cleaning up inside of the hitch with some steel wool or some type of abrasive to clean up the metal. Do this to the ball also. Alot of times, just driving with the trailer a short distance will clean up the connection from the metal grinding and rubbing together. I do not approve of driving without trailer lights, though! You might try this out to see if it helps.
pendleton is offline   Reply With Quote
