Trailer brake magnet continuity across terminals? - JeepForum.com
Go Back JeepForum.com > General > Trailers & Towing > Trailer brake magnet continuity across terminals?
The Ruffstuff 9" Disc Brake brackets!Even Better Heim Pricing! From RuffstuffPANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi
Unread 07-02-2015, 05:07 PM   #1
gemiller
2008 WK
So I had just wired up my brake controller and I couldn't get 12V out of the blue wire no matter what. Called the manufacturer (hopkins) and they figured it to be a bad brake controller. I exchanged it but the problem remains.
Then I noticed something I don't think is right. I wired one lead of each brake magnet to blue brake wire, and 1 to white ground. However I have continuity across those leads, I'm assuming that means at least one of my trailer brake magnets is bad? Is this a correct assumption? Can a shorted magnet caused the trailer brake controller to not send it's 12V?
2008 WK Red Rock Crystal Pearl CRD || Lifted and stuff.
gemiller is offline   Reply With Quote Quick reply to this message
Unread 07-10-2015, 06:37 PM   #2
dporter
no
each is separate circuit
dporter is offline   Reply With Quote Quick reply to this message
