Tractor Supply vs. Lowes Utility Trailers (WJ) - JeepForum.com
Go Back JeepForum.com > General > Trailers & Towing > Tractor Supply vs. Lowes Utility Trailers (WJ)
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! April Instant Rebate: Up to $75 off Flowmaster Products!
Unread 03-12-2015, 04:49 PM   #1
WVUFTBAL83
OK Folks! Bit torn here. I have a 2004 Jeep Grand Cherokee Laredo with the 4.0 L (WJ). I recently put a hitch on my WJ. With that being said, my wife and I have been in the market now for a utility trailer to tow with the WJ. Looking for the 5 x 8 with mesh bottom. Not looking for hardwood flooring because I can have that done for lil to nothing. Save some money in the long run. Now, I've searched craigslist and to be honest with you, I haven't found anything close nor appealing to drop the hammer on.
The trailer we purchase won't be used extremely hard. Recently moved from an apartment to a house and we now have a major need for a utility trailer. *Moving from the City to the Country was the most gratifying change* Basic use for the trailer will be for yard work, moving trash, etc.
Earlier this week, my wife and I went to the local Tractor Supply and Lowes and looked at trailers. I like them both. But I'm a bit partical for Tractor Supply. I love the 13'' tire and bigger fender walls.
What are the perks of each and which one would be beneficial to get now and for the long run.
The specks for each place are below.
Thanks folks!
Tractor Supply -
5 x 8 Utility Trailer, 1,600 lb. Payload Capacity, 2,000 lb. GVWR
Open mesh floor trailer
1-7/8 in. standard coupler
1,600 lb. payload capacity
13 in. tires
4 ft. rear ramp gate
Lowes -
Carry-On Trailer 5-ft x 8-ft Wire Mesh Utility Trailer with Gate5-ft x 8-ft Wire Mesh Utility Trailer with Gate
Payload capacity: 1650 lbs
12" Tires rated 990 lbs each
1- 7/8" Coupler with safety chain
Made in the USA
WVUFTBAL83 is offline   Reply With Quote Quick reply to this message
Unread 03-12-2015, 05:24 PM   #2
smccollamjr
If TSC isn't made in USA I'd go with Lowe's. Otherwise I'd say either will be fine.
'00 TJ/4.0/NV3550/D30(Aussie)/D44(LSD)/3.73s/1"MML/1.25"BL/OME Springs/UCF TT/33s
Build Thread: http://www.jeepinwv.com/forum/viewto...p?f=51&t=26137
SOLD-'96 XJ, Build Thread: http://www.jeepinwv.com/forum/viewtopic.php?f=51&t=6523
smccollamjr is offline   Reply With Quote Quick reply to this message
Unread 03-13-2015, 10:14 AM   #3
Ross
The Lowes in my area has very good customer service. I would buy from them, all other things about equal, becasue of this. I know if I had a probelm with the traielr they would stand behind what they sold.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor.
Ross is offline   Reply With Quote Quick reply to this message
Unread 03-15-2015, 09:26 AM   #4
WVUFTBAL83
Ended up getting the 5 x 8 mesh trailer from Lowes yesterday. Pulled very nice with the WJ.
Looking forward to yard work and house work with warmer weather being here now.
Unread 03-21-2015, 06:15 PM   #5
aspjeepguy
I purchased a 5x10 from TSC about 6 years ago. I sold it when I bought a truck. I sold it for about $200 less than I paid. I was very happy with my purchase.
04 TJ/Rubicon
SuperWinch EPi9.0, Tomken Winch Plate 3" BDS, JKS 1.25" body Lift
255x85R16 on Moabs Rear LOD Swing Away Tire Carrier and Bumper/Body Armor Front Bumper
B&M Short Throw, Rear Alloy USA Axle Shafts
aspjeepguy is offline   Reply With Quote Quick reply to this message
Unread 03-21-2015, 06:21 PM   #6
billiebob
Maybe flip the axle so it rides right.
My Uncles first Jeep was a Government Issued Jeep in 1944.
Back when ALL Jeeps were Government Issued.
billiebob is offline   Reply With Quote Quick reply to this message
Unread 03-25-2015, 11:58 AM   #7
WVUFTBAL83
Y would I flip the axle? It rides fine. For no more than the 5 times I'm going to use it a year, what is the point?
Unread 04-03-2015, 11:16 PM   #8
billiebob
Trailers should be level or lower at the front. That attitude means the load will slide forward as you drive. When the trailer is lower at the back the load wants to slide back with every bump. Proper attitude makes the need to tie things down redundant. You always want to secure the load but if it will push into the front rack it just adds a safety margin. The way your trailer is sitting the load will want to slide back. The outcomes are far worse when things go wrong.
Flipping an axle is Saturday morning stuff.... coffee at 10am.
Unread 04-07-2015, 10:56 AM   #9
Ross
I did a spring over on my trailer so it would ride right.
Unread 04-08-2015, 11:41 PM   #10
billiebob
Me too..
Unread 04-09-2015, 01:38 PM   #11
WVUFTBAL83
Getting 6 yards of mulch on Saturday. All back roads to my house from where I'm getting it from. Nothing over 40 mph. OD on or OD off?
Unread 04-10-2015, 07:25 PM   #12
billiebob
Under 40 mph, towing? I'd say OD off but try both.Let us know what you like.
Unread 04-13-2015, 04:39 PM   #13
WVUFTBAL83
Hauled nine yards of mulch over two trips with this trailer this weekend... The ol 4.0 didn't have a problem at all.
Unread 04-18-2015, 09:34 PM   #14
jagular7
Flipping an axle vs going to spring over axle (SOA) are quite 2 different things but the results of height is the same.
For the basic angle utility trailer, its obvious that there is a slight convex curve to the axle tube. By flipping that axle, the curve is now concave and easier to bend when loaded. With these light weight trailers, the springs are not necessarily the only suspension component. The axle tube will flex as well.
With the design of convex curve, the load does not effect the curve to where it won't 'spring' back. With the axle in a concave position, the axle is more to stay bent for the same load.
I would suggest you get a local welder (muffler shop, 4x4 shop etc) to place spring perches on top of the axle tube. You could also get them to weld on taller spring mounts off the frame to gain even more height.
Now the issue comes as to finding wheels/tires to fill the fender...LOL
To remedy the taller tire, this may require a 'bigger' axle capacity as it leads to wheel surface mount to wheel surface mount measurement and leaf spring center width. The lighter capacity axle is not designed for this. That's why they are offered with 4.8 and 5.2 -12 tires/wheels.
In addition, the head of the leaf spring center pin is designed to be placed into the spring perch on the axle. It would be best to flip that in the leaf. Not too hard to do with a large c-clamp and basic hand tools.
Mike
Jagular
Lnxa, KS
97 TJ SE lifted, locked and rubbered for fun
94 YJ SE stock, 225s, Trail Tested
jagular7 is offline   Reply With Quote Quick reply to this message
Unread 04-19-2015, 12:34 AM   #15
Madden_07
Or, just, you know get a drop hitch. That's what I use when towing my small utility trailer.
"Roads? Where we're going we don't need roads!"
-Dr. Emmett Brown
Madden_07 is offline   Reply With Quote Quick reply to this message
