Towing your jeep question - Page 3 - JeepForum.com
post #31 of 46 Old 02-16-2013, 01:33 AM
threeb
Originally Posted by MPond
Do you pull the rear drive shaft out of the XJ when you dolly-tow it? I don't have an XJ, so I can't say this from first-hand experience, but everything I've read online says that you can't dolly-tow an XJ (or a TJ, CJ, or any other Jeep for that matter) without pulling the rear drive shaft.
That's what they say because the transfer case is still spinning. I removed my rear but I did not unlock my steering.
LJ Owners Group member #431.
threeb is offline
post #32 of 46 Old 02-16-2013, 01:46 AM
MPond
I believe there's more to it than that. When I flat tow my Jeep, my transfer case is still spinning too.
I've heard that the issue is related to the fact that, on a dolly, only half of the transfer case is spinning - the rear output shaft spins while the front is stationary. It's the difference between those 2 that causes a problem.
But I don't have first-hand experience with it, so I was wondering if someone could explain it in more detail.
2006 Black Unlimited 6-speed, Rubicon Express 5.5" Long Arm Kit
MPond is offline
post #33 of 46 Old 02-16-2013, 08:37 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
I have pulled this set-up several times over the past year. Never yanked the rear dshaft. The XJ is an '01 with a 231 t-case. I put the tranny in park, leave the keys out of ignition, t-case in neutral, parking brake off. I drive the XJ back and forth to work and around town errands from time to time (short drives) - only had it on the highway a time or two - but I have had zero issues.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #34 of 46 Old 02-16-2013, 09:05 AM
threeb
Yes, that is the long version. While the rear or front axle is in motion and the other is not it will cause massive failure of the transfer case. That is pretty much the only explanation I could get out of jeep. Flat towing lets them spin at the same rate.
threeb is offline
post #35 of 46 Old 02-17-2013, 05:52 PM
ssquier92
So when I drive around with my front driveshaft pulled when I rebuilt it I should have experienced massive transfer case failure
Come on guys, when it is in 2wd it doesn't matter what that front yoke and chain are doing inside the tcase
These are part time cases, not full time.
2002 TJ 3.25" RC lift, 1.25 BL, MML, 33X12.50 Goodyear MTR w/ Kevlar, adjustable front trac bar, cut stock bumper, poison hood louver, B&M short shifter, chromoly rear axle shafts in the d44 4.88s Grizzly locker, Aussie locker up front in d30,10,500lb winch w/ synthetic rope, antirock, jcr sliders, savvy arms
Work harder, thousands of people on welfare are counting on you.
ssquier92 is offline
post #36 of 46 Old 02-18-2013, 10:45 PM
MPond
I don't know the answer - that's why I asked. But everywhere you look (both online and in most Jeep owner's manuals) it says that you should never dolly tow a Jeep.
Do a quick Google search - you'll see what I'm talking about. Or look at a variety of Jeep owner's manuals.
There's got to be some reason for that...
MPond is offline
post #37 of 46 Old 02-19-2013, 12:05 AM
JeepN4KC
JeepN4KC's Avatar
I have yet to experience any tcase failure.
~Mike~
WK
XJ
JeepN4KC is offline
post #38 of 46 Old 02-25-2013, 11:42 PM
Saul32
1988 FSJ Wagoneer
I need to tow a full size Wagoneer for about 300miles this weekend. Uhauls site keeps telling me to rent a tow dolly and not a tow trailer. Does that sound right?
Nothing important...
Saul32 is offline
post #39 of 46 Old 02-27-2013, 06:55 AM
JeepN4KC
JeepN4KC's Avatar
If your tow rig can handle a trailer go that route. Even if a dolly will work - a trailer is always better.
~Mike~
WK
XJ
JeepN4KC is offline
post #40 of 46 Old 02-27-2013, 07:40 AM
MWilcox
If this were the case you could never do a lock out conversion on a Jeep. It makes no difference to the t-case if the front spins with the rear or not as long as you aren't running an all wheel drive version. Pulling the driveshaft is not at all necessary.
'05 supercharged LJ Rubicon 6-spd, 4 speed Atlas, 6" Teraflex LCG pro, HP 60 front, Tera 60 rear, 5.38's, arb'd, full Tera skids, Raceline bead locks, 40" MT/R's, full cage, OBA, etc...
MWilcox is offline
post #41 of 46 Old 02-27-2013, 07:17 PM
MPond
That's always made sense to me as well; I just can't figure out why the Jeep manual says you can't tolly tow any of the Jeeps with a standard transfer case such as a TJ or JK.
MPond is offline
post #42 of 46 Old 02-28-2013, 05:26 PM
MWilcox
It could be that Jeep doesn't advise it because there will always be that guy that takes off in his motor home towing his Jeep in gear and not realizing it ( my Dad did this). A diesel pusher doesn't even feel a dragging Jeep back there. Instead of possible warr. issues they advise not doing it. Who knows, but I do it, and when you think about the mechanics of it there is no reason not to flat tow or dolly it.
MWilcox is offline
post #43 of 46 Old 02-28-2013, 08:12 PM
JeepN4KC
JeepN4KC's Avatar
I thought of this as well.
But why not just list the correct way to do it instead of mentioning catastrophic failure? I can say with certainty that an '01 XJ, auto, w/ NP231 xfer case can be dollied with no issues.
~Mike~
WK
XJ
JeepN4KC is offline
post #44 of 46 Old 02-28-2013, 09:05 PM
MPond
I don't think that's it, as the TJ & JK manuals says it's okay to tow them 4-wheels down (transfer case in Neutral), but that they cannot be dolly-towed.
MPond is offline
post #45 of 46 Old 10-10-2016, 06:27 PM
aggiejon
1979 CJ7
For lights I added a trailer plug to the front of my Jeep and use that to plug the lights in. Sent from my iPhone using JeepForum
Did you just tie into the rear light harness or did you do it another way?
aggiejon is offline
