Towing your jeep question - Page 2 - JeepForum.com
post #16 of 46 Old 11-06-2012, 01:14 PM
BimotaBruce
I've done both....a lot.
I agree with MPond above says about the flat tow.
The advantages of a trailer have been well laid out too.
Trailers are a PITA to store (and buy). My LJ's still a DD, so flat towing behind an RV is still something I do several times a year...never a problem.
That said, a well set up Wrangler's at least 4500 lbs...and that's going to push around "a van full of people" pretty well....and more importantly than that, it's going to increase your braking distance SIGNIFICANTLY. Your sig shows a Liberty, and I don't know what those weigh.
It may be safest to have someone drive the Jeep, instead of flat towing....especially if you may encounter steep mountains, rain, and/or wind.
BB
4" Currie springs/CA's, TR beadlocks, 35" MTR's, D44's ARB's & 4.27's, RCV & Superior, OR241, UCF TT
BimotaBruce is offline
post #17 of 46 Old 11-08-2012, 01:15 PM
nitecop
I tow mine when using the RV. since its street legal I drive it other wise.
Jim
USW, OAPSE Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline
post #18 of 46 Old 11-11-2012, 11:33 AM
Dngrs1
1979 CJ7
I flat tow my CJ when I can't drive it there. Things to consider: My caster angle is less than it should be and the CJ will exhibit the same wobble/wandering when it approaches 60mph as it does when I drive it so I keep the speed under 60mph. I have a trailer light harness from a plug in the front bumper to the rear lights and have to disconnect the wires from the lighting circuit (next to the drivers seat) to the rear lights or both taillights will flash when using turn signals from the towing vehicle. I remove the rear driveshaft and unlock the steering wheel. The farthest I will tow like this is 100 mi. If I have to go farther, I will rent a trailer.
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline
post #19 of 46 Old 11-11-2012, 10:32 PM
MPond
Two thoughts on this...
1. You can use diodes in order to eliminate the need to disconnect the Jeep's lighting circuit each time you connect. I did this in both my '85 CJ7 and my current '06 LJ. In both cases I did the same as you suggest - have a trailer light harness & plug at or near the front bumper.
2. I've heard of issues with flat-towing a CJ7 because of the transfer case, and I'm wondering if that's why you remove your rear driveshaft. I towed my '85 CJ7 for years without disconnecting without any issues. I'm not sure if I was just lucky or if it's less of an issues than some people suggest about the CJ7? Or maybe different transfer cases in different years? I'm kinda curious on this one.
2006 Black Unlimited 6-speed, Rubicon Express 5.5" Long Arm Kit
MPond is offline
post #20 of 46 Old 11-12-2012, 10:40 AM
Dngrs1
1979 CJ7
Stupid me. I never thought of diodes. As far as the disconnecting of the driveshaft, better safe than sorry.
Dngrs1 is offline
post #21 of 46 Old 12-05-2012, 01:06 PM
89YJBuilder
I would also like info on flat towing. I am considering it for get my rig home after a run when it breaks down on me on the way home. This has happened to me twice in a row now and neither time would it have kept me from flat towing it home. As well how do you connect the draw bar? Does it connect to the bumper pr where? I am gonna build my draw bar. I am a trained fabricator and have worked in a repair shop servicing class A truck and trailers so the draw bar for a YJ isn't a concern. However I would like a suggestion on a length. Thanks for any info.
89YJBuilder is offline
post #22 of 46 Old 12-05-2012, 01:14 PM
89YJBuilder
You can get a set of magnetic tow lights pretty cheap at Tractor Supply or other farm supply stores. You stick them on and rout the harness up to your tow rig's plug and off you go.
post #23 of 46 Old 12-05-2012, 01:19 PM
wilson1010
A set of the magnetic tow lights is invaluable. not only can you use them on the flat towed rig, but also on a rental trailer without good lights and I have even used them for long loads hanging out of the back of my pickup trucks or when the truck lighting is obscured from a bulky load. Plug and go. $40 Great item.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #24 of 46 Old 12-06-2012, 03:53 AM
DeltaForceB85
2011 KK Liberty
Originally Posted by wilson1010
a set of the magnetic tow lights is invaluable. Not only can you use them on the flat towed rig, but also on a rental trailer without good lights and i have even used them for long loads hanging out of the back of my pickup trucks or when the truck lighting is obscured from a bulky load. Plug and go. $40 great item.
:2 thumbs up:
-Josh
DeltaForceB85 is offline
post #25 of 46 Old 12-06-2012, 08:53 AM
MLJeeper
MLJeeper's Avatar
I use a trailer. Less wear, less fuel believe it or not, even with the diesel and a guaranteed way to get home when I break things.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #26 of 46 Old 01-20-2013, 06:32 PM
bigwahini
My wife and I moved to NJ for a month(don't ask), she flat towed my TJ there and back. We used magnetic stick on lights. No issues at all. BTW the odometer didn't add that mileage as the key was only in the "unlock" position. All that said, if I were towing to do some heavy wheeling I would rather use a trailer, in case of breakage.
ifyoubegintothinkyou'relosingcontrol...it'salready gone
bigwahini is offline
post #27 of 46 Old 01-20-2013, 06:52 PM
bigwahini
Get some pics of the draw bar for building. As far as the attachment points go, I used what came with the set-up we bought at Northern Tool and drilled a couple extra holes where the bumper pads used to be. I then strengthened the stock bumper with some heavy guage plate steel on the back side. Worked great.
post #28 of 46 Old 01-27-2013, 11:42 AM
TJDaveX
Motorized toy collector
TJDaveX's Avatar
I used to flat tow for years. Now I have a trailer for all the reasons already posted above.
I used magnetic lights on my rear bumper when I flat towed. Just ran the long wire through the Jeep, under the hood strap, and to the motorhome. I found some used Roadmaster frame mounts, and bought their no frills tow bar.
When I started trailering, I had no extra wires, lights, or diodes on my Jeep.
TJDaveX is offline
post #29 of 46 Old 02-15-2013, 09:47 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
This is my set-up for now:
4.7L V8 in the WK gets the job done with the XJ on the dolly. Not ideal - but it works. Thinking of selling off the WK to get a real tow pig within the year.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #30 of 46 Old 02-16-2013, 12:24 AM
MPond
Do you pull the rear drive shaft out of the XJ when you dolly-tow it? I don't have an XJ, so I can't say this from first-hand experience, but everything I've read online says that you can't dolly-tow an XJ (or a TJ, CJ, or any other Jeep for that matter) without pulling the rear drive shaft.
MPond is offline
