towing truck height vs towed jeep height - JeepForum.com
post #1 of 8 Old 07-23-2012, 10:23 PM Thread Starter
Mud_Hornet
my buddy has a 2008 or 2010 chevy silverado with a v8 with z71 suspension with a tow package, but not 4x4. my jeep tj has 6 in of lift in the front. if the angle of the tow bar is off (as in pointing down) would that be bad? im asking this question because im wanting to flat tow it but not wanting to purchase the towbar until i could get a little more information about the subject.
01' Jeep Wrangler "X" / Disount Tire Co. #15
Mud_Hornet is offline
post #2 of 8 Old 07-23-2012, 10:48 PM
99_TJ_Wyoming
It is meant to be "as flat as possible", this isnt always possible, I would say that as long as the angle isnt steeper than about 10 or 15 degrees you should be ok, just keep in mind that stopping and accelerating will put undue stress on the towbar at the ball, more so when stopping.
99_TJ_Wyoming is offline
post #3 of 8 Old 07-24-2012, 08:13 AM
wilson1010
Just get the proper ball mount and be done with it. http://www.etrailer.com/faq-ballmount.aspx
I have one with a 6" offset for my XJ on 37's. Works fine. Keep all the vectors flat.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #4 of 8 Old 07-24-2012, 10:01 AM
wolfcreek
Pointing down can be very bad because in an emergency braking situation the towed vehicle can pole vault up onto the rear of the tow vehicle.
Do you have a drop hitch you can turn upside down and re-mount the ball?
wolfcreek is offline
post #5 of 8 Old 07-24-2012, 04:52 PM Thread Starter
Mud_Hornet
cool cool. i dont think the degrees should be off anymore than that. ive heard you should leave your key in also so that your steering wheel does not lock? is this true? and thanks for all the help so far!
post #6 of 8 Old 07-25-2012, 12:39 AM
99_TJ_Wyoming
Turn the key forward one position, to unlock the steering, put the transfer case in neutral and the transmission in gear or park, thats important
post #7 of 8 Old 07-31-2012, 10:52 AM
MPond
15 degrees sounds a little high - you should check with your tow bar manufacturer. The manual for my Roadmaster Sterling says no more than a 3" height difference between the center of the receiver and the center of the pins, which is a in the 5-10 degree range.
But that is easily solved with a drop receiver (flipped over if necessary).
2006 Black Unlimited 6-speed, Rubicon Express 5.5" Long Arm Kit
MPond is offline
post #8 of 8 Old 07-31-2012, 11:10 AM
wilson1010
5 degrees sounds a little high. Consider the vector forces when you have the receiver and the tongue at a 15 degree angle to each other and you slam on the brakes at 60 mph. It is equivalent to putting a hydraulic jack under the tongue and trying to force it off the ball. Just get the right ball mount like I said above.
Max Handlebar Raiser Height ayosick General Discussion 4 12-03-2009 04:22 PM
Bumper height ticket onefastmoe General Discussion 53 10-15-2008 11:21 AM
HOA towed my truck, what do I do??!! Timberwood General Discussion 82 04-29-2007 06:21 PM
World Height Record Caribic-TJ General Discussion 6 03-19-2007 02:48 PM
Jeep towed... and the towing company jacked my winch and tools. loudog3114 General Discussion 24 08-15-2006 08:12 PM
