Towing an TJ with and Unlimited - JeepForum.com
post #1 of 11 Old 08-11-2008, 11:32 AM Thread Starter
Iceman0502
Alright guys I know it has been asked thousands of times, but now it is my turn. I hear everyone ask if a TJ can flat tow another TJ, but I have an Unlimited. I am planning on taking a trip from NY to PA (not that far 200 miles) and I want to bring my girlfriends TJ as well.
I need your opinions if the Unlimited can tow the TJ. The Unlimited has a greater towing capacity so I am thinking its alright but I would like your input.
Also I want to buy a tow bar from Harbor Frieght. Its rated 5000 lbs for $50 - does this sounds too cheap?
I appreciate all of your input.
Iceman0502 is offline
post #2 of 11 Old 08-14-2008, 06:57 AM
frumpy
frumpy's Avatar
I don't know what the YJ is rated for but I can give you this bit of info. Yesterday I flat towed my YJ 600km behind a Liberty (rated for 6k lbs). It sucked but was doable. Just took my time, went around 60mph and any lane changes or big bends were done slowly. Braking and starting weren't much of an issue at all.
I think the LJs are rated for about 5k, so if you have to you probably "could" do it
2002 Dodge Dakota quad cab V8
2011 Dodge Grand Caravan
frumpy is offline
post #3 of 11 Old 08-14-2008, 07:56 AM
2005X
i thought the lj was rated at 3500lbs
and according to jeep.com the liberty is rated for 5000lbs not 6000
here is a link i found with the specs for the 2006 LJ, the LJ is on the 2nd page
http://autos.aol.com/cars-Jeep-Wrangler-2006/specs
2005X is offline
post #4 of 11 Old 08-15-2008, 11:25 AM
PeteC
Personally, I would not do it. There is not much of a difference in length and weight between the 2, and 4 down flat towing could very well be problematic, if not scary.
Not to mention that your brakes will have a hard time handling the extra almost 4000 pounds of dead weight.
I tried flat towing my 2000 Tj with the 2007 Commander I had last year. It was down right scary on the expressway, at about 55 mph, going around a very gentle curve. The TJ "pushed" the Commander sideways. A case of the tail waggin the dog. On a trailer, properly set up with weight distributing hitch and brake controller, I could tow the TJ on an 1800 pound trailer at 80 mph (tested once on flat, straight highway with no other vehicles around) and be very comfortable doing it.
If I had to do it I would at the very least get a "Brake Buddy", which is a wireless braking system for the vehicle being towed. This is becoming more prevelant in the RV world as required by law in more and more states for vehicles being flat towed. And I would find a speed where the TJ did not push the LJ......I would imagine this would be relatively slow.
'00 TJ With toys, lift and tires.
'10 Dodge Ram 1500 Quad 4x4. Daily driver and tow rig
'05 Dodge Neon. Wifes daily driver and gas sipper.
There is no Bandaid for Stupidity
Sorry if my support of legal wheeling offends you
PeteC is offline
post #5 of 11 Old 08-17-2008, 06:11 AM Thread Starter
Iceman0502
If some are against flat towing, then what about a car trailer. I know someone who has a car trailer that I use often, especially when I rebuilt my Camaro, but I towed it with my Dad's Excursion and had no problem but that is not the same situation. I am not taking the Excursion.
I think flat towing would be safer than throwing the TJ on the trailer and towing the trailer.
post #6 of 11 Old 08-17-2008, 06:39 AM
frumpy
frumpy's Avatar
I wouldn't even consider that. Most trailers are at least 1500lbs, the TJ is probably 3500, thats 5000lbs behind an LJ (assuming the trailer and TJ are on the lighter side)
frumpy is offline
post #7 of 11 Old 08-17-2008, 09:02 AM
2005X
my 18ft+2ft dovetail which i thought weighed 1800lbs ended up weighing 2700lbs plus my jeep of around 4200lbs equals way to much to pull behind an unlimited, i wouldnt even do it with my toyota FJ which is rated for more than the LJ
2005X is offline
post #8 of 11 Old 08-17-2008, 09:28 AM
MuddyJeepZJ
MuddyJeepZJ's Avatar
There's a reason I traded in my LJ for my Dodge Ram 3500.
2004 Jeep Wrangler Rubicon
2003 Dodge Ram 3500
MuddyJeepZJ is offline
post #9 of 11 Old 08-26-2008, 08:37 PM
shreknow91
2003 KJ Liberty
OK... I have a Question... why can't your GF drive the tj and you drive the LJ?
Stock 2003 KJ limited
Soon: Frankenlift, new tires, CB, Roof rack, and off road lights... :-D
Originally Posted by Rob99 View Post
Yes but does everyone who ate something have a sudden urge to life heavy pallets of stock?
Originally Posted by yjislander View Post
now how do you think it got up there???? Bubba sucked in his gut real good and him and cletus picked it up and prayed they wouldnt dislodge a nut in the process, never underestimate the strength of a few rednecks
shreknow91 is offline
post #10 of 11 Old 08-28-2008, 01:20 PM
1 ton yj
1 ton yj's Avatar
That would be the tail wagging the dog.
1 ton yj is offline
post #11 of 11 Old 01-15-2014, 10:06 AM
LuckyPuck
I wouldn't,
I pull a 3 rail dirtbike trailer with my LJ and it doesn't like it much and thats maybe 1300# loaded. I couldn't imagine pulling triple that.
Not new to the forum, I'm locked out of my account under my old Screename (Vwbeatle1214)
Currently on my 14th Jeep (2006 LJ 4.0 Auto, 3"lift, Pro Comp Extreme wheels, tranny cooler)
LuckyPuck is offline
Towing Ski Boat with JK Unlimited scott06tj Trailers & Towing 5 02-25-2009 04:09 PM
Picture this, Pickup flat towing a jeep, flat towing a jeep Rumpeltiltskin Trailers & Towing 10 08-04-2008 06:29 PM
Towing with my XJ JeepTransformer Trailers & Towing 4 04-20-2008 10:27 PM
XJ towing a TJ PolloLoco Trailers & Towing 3 04-10-2008 12:38 PM
xj vs unlimited towing rugger81 General Discussion 1 03-13-2006 07:57 PM
