Towing car long distance - JeepForum.com
Go Back JeepForum.com > General > Trailers & Towing > Towing car long distance
ARTEC JK UNDER ARMOR - 4 door Bellypan KitsSmittybilt Products at Oconee Off-Road!Advance Adapters SYE Kits
Unread 10-22-2014, 05:08 PM   #1
04wj47
In a couple weeks I will be moving 1100 miles across the country and I need some advice on the best way to tow a car. I have an 04 Grand Cherokee with a 4.7L V8 that I will be using to tow a Toyota Celica. My Jeep did not come from the factory with the tow package. I've installed a hitch and wiring harness and used it to tow lighter trailers the same distance and its worked great. I have experience towing utility trailers but I've never towed a car and I have some concerns.
First is which type of trailer to use. I'll be renting from Uhaul so I have the option of a tow dolly or an auto hauler. I'm aware of the limitations of backing up a tow dolly. What I'm most concerned with is the additional weight of the auto hauler vs the lack of brakes on the tow dolly. With the auto hauler I'm looking at a combined trailer/load weight of about 5000lbs with the added assistance of surge brakes on the trailer. With the dolly the combined weight is about 3600lbs without any trailer brakes. Do the trailer brakes on the auto hauler make up for the extra weight in terms of safety?
Second, I do not have an additional transmission cooler but could install one myself for around $60. Would I need this to tow the auto hauler or will the stock cooler be sufficient? Thanks in advance!
04wj47 is offline   Reply With Quote Quick reply to this message
Unread 10-22-2014, 09:54 PM   #2
smccollamjr
Either way I would install the transmission cooler. I thought U-Haul dollies had surge brakes?? If so I would go with the dolly because it's lighter and won't be as long which reduces the chances of sway.
'00 TJ/4.0/NV3550/D30(Aussie)/D44(LSD)/3.73s/1"MML/1.25"BL/OME Springs/UCF TT/33s
Build Thread: http://www.jeepinwv.com/forum/viewto...p?f=51&t=26137
SOLD-'96 XJ, Build Thread: http://www.jeepinwv.com/forum/viewtopic.php?f=51&t=6523
smccollamjr is offline   Reply With Quote Quick reply to this message
Unread 10-23-2014, 10:16 AM   #3
wilson1010
1100 miles from NY doesn't get you any real hills unless you go out of your way to find some. So, I'd skip the transmission cooler.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406
wilson1010 is offline   Reply With Quote Quick reply to this message
Unread 10-23-2014, 05:29 PM   #4
thantos858
1974 CJ5
Depending on what hitch you installed you might not even have a choice from U-haul. The only brakes on a U-haul auto trailer are surge brakes. If you already have a transmission cooler no need for another one even going over hills if your not being stupid you wont have a problem.
Type of trailer is going to be up to you. I prefer the auto trailer over a dolly. The biggest thing you will have to watch for is sway and being pushed by the car/trailer.
thantos858 is offline   Reply With Quote Quick reply to this message
Unread 10-29-2014, 12:30 PM   #5
Indy
Uhaul car trailers are about 10x heavier than they should be, and their safety margins are substantial. I'd call ahead with the plan and see if they will even rent to you.
A car dolly cuts down on weight, but you end up with 0 tongue weight. Flat towing is a lot different than a trailer. Every time you touch the brakes you basically have another vehicle trying to push you off the road. I used to flat tow a samurai with a heavy 4door f150, not bad. I did the same twice with my GC, sucked.
Odds are im typing on a tablet. It takes too much effort to add some punctuation. Im lazy, get over it
Never underestimate the power of stupid.
Indy is offline   Reply With Quote Quick reply to this message
