Towing behind RV - JeepForum.com
post #1 of 7 Old 09-13-2008, 10:41 AM Thread Starter
melvindrew
Towing behind RV
I have a 1994 Jeep Wrangler 5 speed manual transmission that I want to tow behind my motorhome. Do I have to disconnect my front and rear drivelines to tow this? What is my fastest and easiest option? Can I use a conventional tow bar without removing the drivelines?
melvindrew is offline
post #2 of 7 Old 09-13-2008, 12:33 PM
jbolty
jbolty's Avatar
Don't have to. Transfer case in neutral, transmission in any gear.
Me, and some others ,have had issues with flat towing with an aussie locker installed and have had to drop the drive shaft but you will be fine unless you have that too.
jbolty is offline
post #3 of 7 Old 09-13-2008, 04:33 PM
Maloppa
I baught a jeep up north and went a picked it up, towed it with not trouble that way. My question; why do you need to put the transmission in any gear? That is what the manual says and just curious if any theory or reason behind it. Figured you could just put both in neutral and it would work.
Maloppa is offline
post #4 of 7 Old 09-13-2008, 04:50 PM
wilson1010
The transmission should not rotate with the transfer case in neutral, but if it di it would be bad news (no lubrication on the output end). So the manual says put it in gear or in Park. That way it won't turn.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #5 of 7 Old 09-15-2008, 11:48 PM
enzogy
Granting if its an electronic push button on the fly diff. than you'll drop it is drive shaft.
enzogy is offline
post #6 of 7 Old 09-16-2008, 08:16 AM
Maloppa
Makes sense. Thanks.
Maloppa is offline
post #7 of 7 Old 10-07-2008, 06:29 PM
ptwelve
I plan on flat towing my 98 behind my motorhome and have intentions of adding an aussie/lunchbox locker to the front. Can you inform me why I don't want an aussie locker if I don't want to have to pull my driveshaft?
ptwelve is offline
Picture this, Pickup flat towing a jeep, flat towing a jeep Rumpeltiltskin Trailers & Towing 10 08-04-2008 06:29 PM
WJ Towing 2001wj Trailers & Towing 3 03-25-2007 11:55 AM
Towing bughunter General Discussion 2 03-03-2007 10:21 AM
XJ Towing JeepinCoastie Trailers & Towing 1 02-28-2007 04:22 PM
Towing a '83 CJ7 clarson Trailers & Towing 4 02-09-2007 11:13 AM
