Tow Safety Chains - JeepForum.com
 1Likes
  • 1 Post By smccollamjr
post #1 of 14 Old 03-13-2017, 12:20 AM Thread Starter
grwgoldpro
Tow Safety Chains
I live in California and need to know about safety chains if I can use Straps instead of Chains or Cables for safe towing my XJ.. I don't want to get a ticket.
Gary
grwgoldpro is offline
post #2 of 14 Old 03-13-2017, 03:22 AM
RedJeepster1
Low and Slow
RedJeepster1's Avatar
Why don't you just go to your local hardware store and get some chain? What's the reason for wanting to use something else? Most trailers should already have chain in place and ready to go.
Sent from my iPhone using Tapatalk Pro
88 YJ with a 4.6l stroker, AX-15, NP231, 2.5" lift, 4.10's and 33's
2000 Silver XJ, 4.0, AW4 with 350k+, Locked C8.25 w/ Chromos, Trussed hp30, 4.56's, Stiffened, IRO leafs, RE coils, custom 3 link, WJ knuckles, 35's
RedJeepster1 is offline
post #3 of 14 Old 03-13-2017, 08:53 PM Thread Starter
grwgoldpro
I don't have fixed locations on the XJ to mount them and thought if I secured them to the frame with welded mounts it would be easy. Chains would work as well as cable. Just toying with ideas on how to do it with options. Straps are thinner, lighter and as strong.
Gary
post #4 of 14 Old 03-13-2017, 11:00 PM
ou2mame
Your hitch doesn't have chain loops?
Sent from my HTC M9 using Tapatalk
ou2mame is offline
post #5 of 14 Old 03-14-2017, 04:41 PM Thread Starter
grwgoldpro
The motorhome has loops with the hitch for the safety chaines but my Cherokee has none. I will be towing the Cherokee with the motorhome.
Gary
post #6 of 14 Old 03-15-2017, 05:45 AM
RedJeepster1
Low and Slow
Ohhhh, ok. I didn't understand this the first time when I read it. You are flat towing your XJ behind the motor home. I don't know the legality of using cables or rope in place of chain. Your tow bar doesn't have anywhere to attach a chain? All the ones I have ever seen have loops for chain.
post #7 of 14 Old 03-15-2017, 12:09 PM
ou2mame
Yeah I've always seen the tow bars with the loops. My plan is to flat tow mine too. What tow setup are you using?
ou2mame is offline
post #8 of 14 Old 03-15-2017, 02:52 PM
un4gvn1
un4gvn1's Avatar
1988 XJ Cherokee
For flat towing, most tow bars have the safety chains included as part of the tow package. They attach (at least the ones I've used) to the tow bar, not the towed vehicle.
Check other towing laws also, here in Oregon the Cherokee is too heavy to tow four-down without a remote braking system (Brake Buddy or the like). These can cost nearly what a used trailer will run ya'.
Working with cars is a little like a really awesome date: you start out expecting this to be something simple and straightforward; four hours later you're laying under her, panting and cursing, and things are a lot more complicated than you thought.
un4gvn1 is offline
post #9 of 14 Old 03-16-2017, 01:57 PM Thread Starter
grwgoldpro
Dumb Me
I was off base. I never towed a vehicle before so I was going from my experience with trailers and safety chains. Thanks for putting up with my malarkey. The safety chains do go from the Motorhome to the tow bar and not to the towed vehicle. Saves me a headache. I ordered a Smittybuilt 87450 Tow Bar yesterday and verified it will work with the Logan 3/4" D Ring bumper. Problem solved. Sorry if I confused anybody besides myself.
Gary
post #10 of 14 Old 03-16-2017, 02:01 PM Thread Starter
grwgoldpro
I own a Brake Buddy too.
Gary
post #11 of 14 Old 03-16-2017, 09:11 PM
smccollamjr
That's a good looking bumper.
'00 TJ/4.0/NV3550/D30(Aussie)/D44(LSD)/3.73s/1"MML/1.25"BL/OME Springs/UCF TT/33s
Build Thread:
SOLD-'96 XJ, Build Thread:
smccollamjr is offline
post #12 of 14 Old 03-21-2017, 05:13 PM
11B-33T
x2 on that statement; appears to make hooking up easy-peasey. Shame you had to mar it with a license plate.
11B-33T
- 2005 Ford Escape XLT AWD
- 2004 WJ Grand Cherokee SE
- 2003.5 Mazdaspeed Protege
11B-33T is offline
post #13 of 14 Old 03-25-2017, 08:21 PM
wilson1010
Nice bumper.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #14 of 14 Old 03-26-2017, 07:16 AM
smccollamjr
Does that bumper tie farther back in the "frame" than the stock bumper? If not I'd come up with a way to do it.
puppybreath likes this.
Build Thread:
