tow rig... - JeepForum.com
post #1 of 8 Old 07-10-2010, 07:21 AM Thread Starter
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
tow rig...
Made a "tow bar" for the big rig....
3/8" plate drops down from my ramps (I pull RGN trailers and blade trailers).
Then I plasma cut out for the 5 x 2 x 1/4 and welded it through the sides of the 3/8". Receiver tube is welded to the top of the 5x2 with gusset's.
Ties into my light wiring for the electrics and good to go. I bought a brake controller, but highly doubt I will run out of brakes on the "tow rig"....
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #2 of 8 Old 07-10-2010, 07:56 AM
jhurt
You may want to recheck the rating on that tow rig, I'm not sure it's designed to pull that much weight.
'00 TJ 3 spd, D30 aussie locker/8.8 E-Locker, Currie springs, Savvy/Currie arms
jhurt is offline
post #3 of 8 Old 07-10-2010, 09:28 AM Thread Starter
leftlanetruckin
XJ on 37's
I know....I am only registered to gross 117,000lbs....
post #4 of 8 Old 07-10-2010, 10:55 AM
jonwood
Pimp "Tow Rig"
03 Rubicon on 36's and LONGFIELD CV's
jonwood is offline
post #5 of 8 Old 08-13-2010, 04:29 PM
gribbles
I think the statement "you cant even tell its back there" might actually apply here
2000 TJ, 100" wb on leaves
2007 WK CRD
gribbles is offline
post #6 of 8 Old 09-02-2010, 07:49 AM
horatio102
Why not just build some beefy fenders and drive the Jeep up on the back??
horatio102 is offline
post #7 of 8 Old 09-02-2010, 07:56 AM Thread Starter
leftlanetruckin
XJ on 37's
Because it still has to make a living when play time is over!
trailer hitch is out of the way, fenders over the top would be a minor inconvenience.....
Would be kinda nice though huh?
martin
post #8 of 8 Old 09-02-2010, 08:05 AM
horatio102
I bet with some time you could come up with a design that wouldn't be in the way.
