Tow auto trans in neutral? - JeepForum.com
Go Back JeepForum.com > General > Trailers & Towing > Tow auto trans in neutral?
Poison Spyder from CCOR!Rough Country Lift Kits and Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-20-2009, 09:45 PM   #1
kcpep
Towing a TJ, Auto Trans., 200 mi. this weekend on a Uhaul dolly. Uhaul says the drive shaft must be removed. Other folks telling me it's OK to tow with the trans. in Neutral. Which is it? I don't want to destroy the trans. on the way home, but if it won't hurt to put it in Neutral... Why would Uhaul tell me to remove the driveshaft? Thanks
kcpep is offline   Reply With Quote
Unread 01-21-2009, 09:48 AM   #2
wilson1010
Check your manual. It will tell you to put the transfer case selector in neutral and the transmission in Park. U-Haul is run by morons and crooks.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406
wilson1010 is offline   Reply With Quote
Unread 01-21-2009, 05:01 PM   #3
kcpep
I'm making the trip to purchase the Jeep, so I don't have a manual. I called the local Jeep dealership today and the say drop the driveshaft. Thanks
Unread 01-21-2009, 06:17 PM   #4
wilson1010
Your dealer is a moron too.
Pages 248-250 from the 2006 TJ manual:
Unread 01-21-2009, 08:25 PM   #5
kcpep
Thanks Wilson!
Unread 01-21-2009, 09:43 PM   #6
wilson1010
You're very welcome. I hope you have a great time with your new Wrangler!
Unread 01-21-2009, 09:46 PM   #7
SpydermanTJ
Just note that it says NOT to use a dolly!!!! Unless you have a few grand to repair your new Jeeps t-case or tranny. Use a frame-mounted towbar.
2000 4dr XJ 2WD, 4.0L auto
Gone, but not forgotten- 1998 TJ Sport
Nightcrew #162
"i'd want a bottle of 12 year old scotch and a 24 pack of rubbers. i'll go places with a hard-on that most people wont go with a mechanized infantry batallion."
SpydermanTJ is offline   Reply With Quote
Unread 01-21-2009, 10:20 PM   #8
wilson1010
Why do I even try?
Unread 01-22-2009, 03:01 PM   #9
jbolty
ISO 9001 Compliant
jbolty's Avatar
You may have to drop the rear drive shaft if using a dolly. Why you say? Because with many versions of the 231 transfer case there is not a "true" neutral. What that means is when the t-case is in neutral it is disconnected from the transmission and from power. BUT, the front and rear are still connected. Test it by jacking all 4 wheels off the ground and with the tcase in N spin one of the tires and see what happens to the others.
The references above scanned from the manual are for flat towing but the same issues apply if you have a lunchbox locker in the front and are flat towing
Your mileage may vary but it's easy to test it.
more detailed info here
http://www.jeepforum.com/forum/showp...1&postcount=20
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote
Unread 01-22-2009, 04:47 PM   #10
h2ojeep
1978 CJ7
As easy as it is to drop the drive shaft, I would drop it and be on my way, to me it would be a no brainer,
h2ojeep is offline   Reply With Quote
