TJ hitch Class 2 vs. 5 - JeepForum.com
post #1 of 3 Old 12-30-2010, 03:26 PM Thread Starter
chadsmeltzer
chadsmeltzer's Avatar
I just replaced my Class 2 hitch with a Class 5 hitch and was really surprised at how they are built. My only reason to upgrade was to go from a 1.25" to 2" so I could use it for recovery. Both hitches were rated for 3,500lbs/350lbs tongue which is still over the TJ limit so that doesn't really matter.
I first thought it was odd that the Class 5 (V) hitch was only rated at 3,500 as it is considered "Extra-Heavy Duty" and normally around 12,000 lbs.
Then I saw that my class 2 hitch had 6 mounting locations and the class 5 only has 4, not too mention much beefier side supports. The receiver itself also has a plate top and bottom of it, whereas the class 5 only has one on top. The hitches are all the same thickness too.
I would have to say the class 2 hitch is MUCH stronger then the class 5 I replaced it with, but unfortunately I couldn't use it for recovery. I guess I will just have to hope the new one is strong enough, I might weld on extensions on both side so it has 2 bolts on each side like the class 2 did.
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline
post #2 of 3 Old 12-30-2010, 10:23 PM
Fourtrail
1974 CJ6
From U-Hauls web site
V-5 A minimum testing/rating system of trailer hitches established by the Trailer Hitch Manufacturers Association.
That is still a class 2 hitch, not a class 5.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is online now
post #3 of 3 Old 12-30-2010, 11:10 PM Thread Starter
chadsmeltzer
Never thought of that before, thanks for finding it. It would be a class 3 then, a hitch with a 2" receiver is at least a class 3.
I guess it doesn't really matter, it's still over the tow rating of the Jeep.
where 2 get heavy duty hitch (class 4/500 lb. tongue weight) for an 87 wrangler YJ? submaniac Trailers & Towing 7 08-30-2015 09:00 PM
MMA class ImpactFabWorks General Discussion 7 08-25-2009 05:19 PM
Do I take a MIG or TIG class? mike_dippert General Discussion 13 11-08-2007 08:39 PM
need some help in a class. red96jeep General Discussion 22 01-26-2007 01:53 AM
Why ND is 1st Class... Shinner General Discussion 18 11-15-2005 11:34 AM
