Tire Pressure Monitor System (TPMS) for trailer - JeepForum.com
post #1 of 14 Old 10-02-2015, 08:35 PM Thread Starter
TSEJEEPERS
Anyone using one?
What kind and how do you like it?
The ones I am seeing monitor the tire pressure and the temp.
I would think something like this could really save you a lot of problems.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #2 of 14 Old 10-03-2015, 06:05 AM
wilson1010
Waste of time and money. And, reliance on goofy aftermarket gadgets is what will lead to trouble.
Don't overload your trailer, fit the proper tires, walk around your rig every time you embark, and get a $.98 tire gauge to get the exact number whenever you suspect a need for more or less pressure. Carry an OBA setup of some type and a good trailer spare.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #3 of 14 Old 10-03-2015, 06:01 PM Thread Starter
TSEJEEPERS
I am not sure I agree Wilson.
The reason I say this is many times a trailer tire will blow even though it is at the right pressure and still looks good.
I have had a few issues that a TPMS may have had helped avoid.
The first one was pulling out of a gas station. I must have rubbed up against the island on the way out. It broke the valve stem. I did not realize it until I was back on the highway. I had to change a tire on a 3 lane highway and it ruined the tire.
The last one was the brake lining came off of the brake shoe. It was shock loading the wheel. It ended up shearing the studs and the tire and rim took off across the road. It was a two lane road and I am lucky it did not hit another vehicle. It ruined the hub and rim.
Now before you say that is just basic maintenance, I maintain my trailer. The bearings get packed every year at least. Matter of fact I had just packed my bearings for that trip. There was no sign that the lining was coming off.
post #4 of 14 Old 10-04-2015, 07:04 AM
wilson1010
How could it hurt to do both? Only in the wallet I suppose. So, if the OP can overcome human nature, good for him. My expectation, however, is that this gadget will do to the tire gauge what the idiot lights did to the dip stick.
post #5 of 14 Old 10-04-2015, 09:54 AM
MPond
A good TPMS is worth it's weight In gold. I use one in my RV that tells me the tire pressure and temps, and here's the perfect example why:
Last April my 10-year-old TPMS system failed in the middle of a trip to Moab, so I went back to checking the tire pressure manually each morning. I had a set of 6 new tires on the bus that were less than 6 months old, so I wasn't too concerned, but I am diligent about checking the rig out every morning before we roll out.
On the way back to California, I had a valve stem fail on my driver-side inner dual. Without the TPMS system, I didn't know it was going down until it was too late. The blowout and roadside repair cost me more than the new TPMS system that replaced the old one.
If the TPMS system had been functioning that day, I'd have receiver a low pressure warning before it blew out, and could have stopped, avoided the roadside repair costs, and possibly saved the tire. Instead, I sat on the side of the road for 5 hours in St. George, Utah waiting for the truck tire service.
2006 Black Unlimited 6-speed, Rubicon Express 5.5" Long Arm Kit
MPond is offline
post #6 of 14 Old 10-05-2015, 05:56 AM
wilson1010
I suppose I'll have to re-think it if Pond swears by it.
post #7 of 14 Old 10-05-2015, 06:39 AM Thread Starter
TSEJEEPERS
What kind are you using Pond?
post #8 of 14 Old 10-05-2015, 12:35 PM
MPond
LOL - I'm not usually one for "gadgets" in my cars, but now that TPMS is required on all new cars sold in the US, you've got to think they're onto something...
For me it's the peace-of-mind factor when you've been on the road for 4-5 hours - just glance down and you can see that all the tires are properly inflates, good temps, etc...
I did a bunch of research earlier this year when I replaced mine, and I decided to go with the TST 507 system:
http://tsttruck.com/product/507-starter-system-kit/
MPond is offline
post #9 of 14 Old 10-05-2015, 01:38 PM Thread Starter
TSEJEEPERS
Thanks!
post #10 of 14 Old 05-15-2017, 12:10 PM Thread Starter
TSEJEEPERS
Bringing this back up.
I recently bought a TST 507 system.
It is not installed yet.
I will let you know how it works out.
post #11 of 14 Old 05-20-2017, 06:19 PM Thread Starter
TSEJEEPERS
I do have it installed now.
Not hard to do and set the tire psi and location.
My first trip will be Memorial Day week end.
I will let you know how it goes.
post #12 of 14 Old 05-29-2017, 06:22 AM Thread Starter
TSEJEEPERS
It worked great!
Tire pressure went up around 5 psi on the road.
Temp was running right around 80 degrees. Outside temp was around 71.
Total cost was right around $275.00 with the repeater.
I am going to Moab in a couple weeks, 1200 mile one way. It will be nice to know if there is a problem a head of time.
post #13 of 14 Old 05-30-2017, 06:08 PM
TimV
I didn't even know these existed until I read about them here. Definitely considering a setup now, as I am always concerned about the tires when towing.
Although I am planning on putting a new set of tires on my trailer sometime this year. I still need to measure, but I'm hoping to go from 205/75/R15 to the Maxxis radials in 225/75/R15. They can be found in a higher load range in that size, which should help with any potential issues. Not sure I'll be able to spring for new tires and a tpms system in the same year.
It's not an addiction. It's a way of life.
TimV is offline
post #14 of 14 Old 05-30-2017, 07:35 PM Thread Starter
TSEJEEPERS
I am not sure whether or not I needed the repeater or not. That was $50.
These things are set up for 18 wheelers so you can add sensors if you decide to.
I also went with the ones with replaceable batteries. They last around a year. The others last around 5 years and you have to send them in to be replaced.
I was a little weary about the longer lasting ones because who knows the OE companies may end up putting them in stock form which would put these companies out of business.
