Thinking long term... Good vehicle setup to trailer the heep? - JeepForum.com
post #1 of 35 Old 05-01-2010, 08:23 PM Thread Starter
guht
At some point I would like to pick up a used vehicle to trailer the 2004 TJ. At that point I expect the heep will have grown into that role. It should weigh substantially more with its amror, full roll cage, bumpers, winch, upgraded axles, and lets not forget the 35-37" tires on 17's.
I would like a used vehicle that can comfortably fit 4-5 people, or me the wife, and the mutts. A vehicle that is known for its reliability, is easy to work on (meaning you can crawl in the engine, you dont have to take apart entire engine to get to simple stuff like water pump, the less moving parts the better type mentality), and a large availability of cheap and easy to find parts. Of course it would be nice to not have to work on it at all, but if I do I would like it to be as little a pain in the a$$ as possible.
Obviously it needs to be able to tow the heep without problem, the most inexpensive solution is also sought, and of course the most fuel efficient would be nice.
When mentioning vehicle please provide specific years, or year ranges, since we all know every model has their good years, and their bad years!
Thanks!
2004 TJ SE, 2.4L 4Banger, 5-Spd Manual NVG1500 Tranny, NV 231 Transfercase, D30/D35, 4:11, 245/75R16 Goodyear M/T, Rock Hard Rock Sliders, Master Flow MF-1050 onboard air
guht is offline
post #2 of 35 Old 05-01-2010, 08:25 PM
never monday
F250 crew cab with a 7.3 turbo diesel
never monday is offline
post #3 of 35 Old 05-01-2010, 08:28 PM
little_Jeep
When you say MPG, I'll assume you mean while towing. A 1999 & newer Dodge Ram 2500 or 3500 with the Cummins diesel and quad or crew cab will give you lots of room for the family and lots of power to pull whatever you desire.
little_Jeep is offline
post #4 of 35 Old 05-01-2010, 10:11 PM
Sccafire
X2 I have an 07 2500 CTD.
Scott
"life is good at 2 MPH"
Sccafire is offline
post #5 of 35 Old 05-01-2010, 10:19 PM
LJameson
Either a 7.3 Ford or Dodge with a Cummins. Both trucks are great.
1990 YJ
LJameson is offline
post #6 of 35 Old 05-01-2010, 10:22 PM
stuff2c
just spend the cash and get a new 2011 FORD 6.7 power stroke that thing is NASTY...
YouTube - Ford F450 Super Duty Diesel 150,000 Mile Tow Test
Thanks to the interstate highway system... most people don't see nut'n in the USA.
stuff2c is offline
post #7 of 35 Old 05-01-2010, 10:27 PM
sduncan
sduncan's Avatar
A clean 01-early 03 Ford with the 7.3. Add a nice tune from DB Tuner, a set of guages, air and exhaust improvements and possibly a 31 row trans cooler from a 6.0 truck and run it. Ignore the 6.0 engine at all costs. Next choice would be an 02-later Dodge with the Cummins. The interior of the Superduty offers more room but the Cummins is a great motor. Next, the Duramax. Good motor thru the years but there are several different variations of it. Allison is a good trans as well. But, the IFS is barely adequate and will need $2k in repairs (bushings,bearings,steering etc.) in 50k or less miles depending on tire size. Sorry GM, but your front ends suck..
By all means, get the DIESEL motor in whatever you buy. I have an 01 PSD F350 that has been an excellent truck. Wouldn't trade it for nothing. I have watched my buddies go thru Fords, Duramaxes, and Dodges and I've always just hung onto my 01.
'98 TJ, 5.7 HEMI,
sduncan is offline
post #8 of 35 Old 05-01-2010, 10:46 PM
LJameson
This. My mom has a 2005 with the 6.0 and it's a piece of crap. The rest of the truck is nice (King Ranch) but the motor has nothing but problems.
1990 YJ
LJameson is offline
post #9 of 35 Old 05-02-2010, 04:18 AM
Deacon
Shining Adonis
Deacon's Avatar
That's a lot like saying, "upgrading to an S35 kit is polishing a turd and should be avoided at all costs"...something that sounds good if all you know is what you've read on the internet or a limited sample.
Like most things, it really depends. The 6.0 on my '07 F250 has been fantastic (now 155k miles). You just need to keep up with the maintenance, making sure you keep clean oil in it, as oil drives everything in it, basically. Also, it does help to get the '07 (or '06 earliest) as they worked out some of the kinks from the earlier years. Don't chip it, though. Leave it stock.
Deacon is offline
post #10 of 35 Old 05-02-2010, 04:45 AM
tanksoldier
For what it's worth, I drive a 2003 F-250 6.0L crewcab bought new and now with 103,000mi.
Only had two problems: A sensor that was a pain to replace due to the location but is fairly innocuous itself and having to replace the tie-rod ends, which DOES seem to be an issue with this truck.
All the 6.0L engine problems others rant about: Haven't seen 'em. Just lucky I guess.
tanksoldier is offline
post #11 of 35 Old 05-02-2010, 05:42 AM
stuff2c
fix a 6.0... replace all the head bolts w block studs and upgrade the gaskets. A LOT of the 6.0 problems are caused by aftermarket tuners... remember before you bash me i said "a lot" not all, kuz the 6.0 does have issues. I don't think i'd buy one
stuff2c is offline
post #12 of 35 Old 05-02-2010, 06:56 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
x2. 2002-ish, with manual trans.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #13 of 35 Old 05-02-2010, 07:19 AM
grogie
M-F: Cell Block #4533
grogie's Avatar
Wow... sign me up that kind of a trip! The modern trucks are really amazing. I have to say Fords have a great ride.
Now my father-in-law has an '04 Cummins 2500 Ram 2500 that he tows a 40 ft. trailer with and it's been very reliable for him. It's doesn't sweat at all towing over the Rockies.
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
2013 Off-Road Trailer -
from the onslaught of young idealists. -- Don Colacho
grogie is offline
post #14 of 35 Old 05-02-2010, 08:18 AM
jdhallissey
I am getting a 99 f250 with the Z-6 speed trans WAHOOO! That or get a excursion with the 7.3 in it
jdhallissey is offline
post #15 of 35 Old 05-02-2010, 08:31 AM Thread Starter
guht
Thanks for the replies! The Ford with the 7.3 sounds like its a popular choice, and it looks like it retains its value well!
I know someone that had Ford 250, not sure if he had 7.3, but he had some kind of injector problem what was expensive as hell to fix 2K+... I also know someone with excursion with the 7.3, that had same problem. Has anyone heard of this, and is this something that effects certain years, models, engines?
Also, what kinda miles, price range should I be looking at at for a good deal?
When pricing last night, I ran across this local ad, it made me laugh, so I thought I would share. Look towards bottom of ad!
FORD - When you need to haul A$$!
Thanks!
guht is offline
Long term vehicle storage. Flyingpirate TJ Wrangler Technical Forum 7 06-15-2009 06:01 AM
Long term Storage Libtekguy TJ Wrangler Technical Forum 5 10-20-2007 04:12 PM
Thinking of Rhino Lining my heep bryris YJ Wrangler Technical Forum 4 08-29-2007 01:41 PM
Long term YJ affair mYJ YJ Wrangler Technical Forum 0 06-03-2005 04:49 PM
