Tekonsha Prodigy Install help - JeepForum.com
post #1 of 7 Old 03-15-2009, 11:13 AM Thread Starter
TheGillz
Ok, worked I won't tell you how many hours wiring in a Tekonsha Prodigy brake controller EXACTLY like the manual said. Got a matching blue wire to run back to the trailer plug, used butt connectors to attach the wire to the brake switch. and ran the ground strait to the battery (-) as suggested, and also ran the power straight to the battery via a newly aquired 20A resetting breaker as suggested.
Ok anyone guess the problem yet?
anyone? Spoiler alert!
The power is always on!
So where in the heck do I have to wire 12ga wire through the ignition and then on to my breaker and then to the battery??? I don't get it.
When I have installed stereo's there is the wire to the ignition and the one to the battery, I guess I assumed the wire to the break switch is the equivalent, but no.
Help.
2008 Unlimited X-Jeep Green:Dual Top:6-Spd:Tow-Group:Trac-loc Lim Slip:Hauls: HOT wife, two girls (11&7), Newf
.....|||||__.||._|__-
0lllllll0
.....|/\\_|__|---------<=##=>
..... (o)_)-)_)........(o)_))_(o)_))_)
TheGillz is offline
post #2 of 7 Old 03-15-2009, 01:40 PM Thread Starter
TheGillz
OK, false alarm. The contoller seems to go off on a timer. So when I entered the Jeep the next time, it was off untill I pressed the brake. We are all good and it works famously!!! So excited leaving for southern UT this friday!!
0lllllll0
TheGillz is offline
post #3 of 7 Old 10-23-2012, 06:53 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Okay - I realize this thread is ancient:
But - I've been doing some researching on brake controllers and this was exactly one of my questions. I'm looking at potentially getting a Tekonsha Primus IQ to wire into my 4.7 WK with Class IV tow package. I've tracked down the wiring procedure and which wires to splice into but when it comes to the power being run to the battery with a 20A breaker I wondered the same thing - wouldn't it always be powered on?
So - do most Tekonsha brake controllers have a timer that auto powers down?
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #4 of 7 Old 10-24-2012, 09:29 PM
ctorj
1977 CJ7
They have Sensors in them for movement. So when they do not sense any movement (or brakes pushed) they will turn off. However if you only have 1 battery and it is windy one night expect a dead battery in the morning. I've learned this the hard way. They may of fixed this issue in the new ones.
ctorj is offline
post #5 of 7 Old 10-25-2012, 08:47 AM
Indy
Indy's Avatar
Put a switch inline, solved.
I'm the only gay eskimo.
Indy is offline
post #6 of 7 Old 10-25-2012, 12:47 PM
JeepN4KC
JeepN4KC's Avatar
^^^ This was what I figured the solution was if they don't power down. Either that or just unplug the unit.
~Mike~
WK
XJ
JeepN4KC is offline
post #7 of 7 Old 10-25-2012, 03:18 PM
bgredjeep
1987 YJ Wrangler
I run one in my Dodge. The unit turns on when I hit the brake the first time. It stays on all the time when the vehicle is started, and turns off w/ a timer when the truck is off. I've never had my p3 controller turn of due to anything other than pressing the brake. Even if I start the truck, it doesn't power the controller on until I press the brakes.
bgredjeep is offline
ARB Install rlk_99 General Discussion 4 03-16-2009 07:27 PM
Installing Tekonsha P3.... waterboarder Trailers & Towing 1 08-03-2008 08:06 PM
Brake Controller: Tekonsha Prodigy vs P3 waterboarder Trailers & Towing 7 07-21-2008 07:47 PM
Looking for BL and MML install help Panici General Discussion 3 08-20-2007 11:13 PM
install help of a SYE we3jeepers General Discussion 1 09-28-2004 12:22 AM
