Sports Trailer - JeepForum.com
post #1 of 14 Old 05-09-2012, 11:05 AM Thread Starter
mickmeister
Sports Trailer
My wife and I do a lot of outdoor recreational sports. I had looked at several different trailers, such as the Yakima RackandRoll, but for $2250, I knew I could build a much better, multisport trailer. I have started fabricating it to pull our canoe, kayaks, and dirt bikes. I am building it so that it can be flipped over for one side to carry the dirt bikes and the other side to carry the water sports equipment. I have also made a 12'6" beam that will attach the the front to extend the trailer out for the canoe. I also have an additional 4' piece to attach to the canoe extension so that the trailer becomes a 20' trailer for transporting the steel beams for future projects. Sure beats the 20' beams hanging over both the front and back of the Jeep!
NRA Life Member
mickmeister is offline
post #2 of 14 Old 05-09-2012, 11:48 AM
Boreal
Boreal's Avatar
Interesting. I will be watching this one...
Boreal is offline
post #3 of 14 Old 05-09-2012, 12:08 PM
jhurt
Sorry for the slightly off topic question...but in the first picture is that a magnetic welding ground? I'm a pretty novice welder but I saw one of those in a welding supply store recently and thought it looks pretty handy, but had no idea how well it works so I didn't buy it.
'00 TJ 3 spd, D30 aussie locker/8.8 E-Locker, Currie springs, Savvy/Currie arms
jhurt is offline
post #4 of 14 Old 05-09-2012, 12:26 PM Thread Starter
mickmeister
It works perfectly. As you can see in the pic, I now have no other way of connecting the ground to the steel as I have closed off all of the ends. Definitely worth getting!
NRA Life Member
post #5 of 14 Old 05-09-2012, 10:37 PM Thread Starter
mickmeister
NRA Life Member
post #6 of 14 Old 05-13-2012, 07:54 PM Thread Starter
mickmeister
Here are some more pics of the trailer after finishing more of it today. The next thing will be getting the wheels and fitting them on and welding the spindles to the spindle mounts, before attaching the mounts to the trailer.
NRA Life Member
post #7 of 14 Old 05-20-2012, 08:24 PM Thread Starter
mickmeister
Here is the final picture of the main portion of the trailer. I am still working on the canoe extension, but should have that done in another day. I used one of my mountain bikes as a test for the trailer.
NRA Life Member
post #8 of 14 Old 05-23-2012, 07:17 AM Thread Starter
mickmeister
Here is a pic of it with the canoe extension. The extension still needs to caps welded onto the ends and the bolts attached to the arms for the Yakima bars to be mounted. At that point, I can paint it and install the Yakima canoe holder. That is the final piece of the trailer and it is finished. There will be one more piece, and that will be the dirt bike rails to mount on the opposite side of the trailer, but I am waiting on that until we actually buy our dirt bikes later this year.
NRA Life Member
post #9 of 14 Old 05-23-2012, 09:46 AM
Boreal
Boreal's Avatar
Very cool idea. Are you planning on any sort of detachable fenders/wheel wells or anything? If TN is like UT, a trailer of that size does not need to be registered, so they wouldn't be necessary, but it might be kinda nice to keep the road spray down tho while you're traveling.
Boreal is offline
post #10 of 14 Old 05-23-2012, 10:06 AM Thread Starter
mickmeister
Thanks. Yes. I am going to mount fenders on it and make the switchable by welding bolts sticking up on the top and bottom sides so that I can just unscrew the fender off of one side and flip it to the other. As for the towing lights and license plate, I am going to use wireless towing lights that I found the other day at TSC and then make a plate holder that will swivel over to match the side the trailer is sitting on. The reason I am getting it licensed is because I know we definitely will be going out of state sometimes and it definitely has to be licensed at that point.
NRA Life Member
post #11 of 14 Old 05-23-2012, 03:23 PM
Boreal
Boreal's Avatar
Good plan. I ended up licensing my little M416 for the same reason. We used it to haul gear to Half Moon Bay and Lake Tahoe last summer... Cali definitely requires registration
Boreal is offline
post #12 of 14 Old 05-28-2012, 10:55 PM
Burlbook48
Burlbook48's Avatar
Little late but... you can always tack-weld a little piece of flat stock to the frame somewhere and use that as a ground point. Project done and ready to paint? Grind the tack weld away and you'll never know the flat stock was there.
Interesting idea for a multi-use trailer. I like anything that can be made to fill different needs as your demands change. How's the cargo gunna handle the ride with no suspension? Or am I missing some sort of independant torsion bar set-up?
You have to start somewhere to get to the middle of nowhere.
2015 YJ Of The Year
Thanks, but my rig is just a Prince among Kings. You folks gave me the answers to build it!
Burlbook48 is offline
post #13 of 14 Old 06-04-2012, 09:46 PM Thread Starter
mickmeister
That is a good point! Thanks.
There really isn't any need for suspension on it. It is mainly hauling our canoes, kayaks, river boards, and bicycles. We don't have the dirt bikes yet, but I have looked at other motorcycle trailers and some don't have suspension on them, so I am not really that worried about that.
NRA Life Member
post #14 of 14 Old 06-04-2012, 09:48 PM Thread Starter
mickmeister
You all can take a look at all of my pics on my Facebook album of the project.
NRA Life Member
converting my 4'x6' utility trailer into a mild off road trailer. CowboyT2 General Discussion 3 06-03-2011 04:58 AM
Bear Trailer Sports TedderX_ Outdoor Recreation 4 02-11-2009 10:44 PM
Best used sports car for $12K-15K GringoLoco General Discussion 49 05-29-2008 02:06 AM
Sports Black Hills TJ General Discussion 25 03-06-2006 03:21 AM
Never really followed sports balloo93 General Discussion 14 08-10-2004 03:46 PM
