Shortest trailer to haul two jeeps? - JeepForum.com
Go Back JeepForum.com > General > Trailers & Towing > Shortest trailer to haul two jeeps?
TJ BDS 2" suspension lift!! FINALLY a GREAT 2" lNitro Gear Packages Now Available at Rockridge 4wdFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 04-25-2014, 03:24 PM   #1
jason280
I am looking at picking up a trailer to haul both a '94 YJ and '85 CJ-7. The YJ has a 3.5" lift with 33-12.50s, whereas the CJ-7 is stock with 31" tires. I know my YJ weighs right around 3300lbs, and the CJ-7 should be about the same, so weight won't be an issue. I just need to know the shortest trailer I can pick up that will still easily fit both. I know 28' will work, but how about a 25-26' trailer? Thanks!
jason280 is offline   Reply With Quote Quick reply to this message
Unread 04-25-2014, 06:08 PM   #2
wilson1010
The shorter you go the harder it is to tie them down properly. A nice angle for the tie downs is better than straight up and down. So be sure you really need the extra two feet or whatnot.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406
wilson1010 is online now   Reply With Quote Quick reply to this message
Unread 04-25-2014, 06:40 PM   #3
jason280
I'm well aware of the issues with securing the two Jeeps, that's not the question. I just simply want to know the shortest trailer I can get by with, and still have room for both. As long as they will fit, securing them won't be a problem.
Unread 04-25-2014, 08:00 PM   #4
smccollamjr
Measure the two Jeeps. Add those numbers together. Get a trailer with a deck greater than or equal to the sum of the length of both Jeeps.
'00 TJ/4.0/NV3550/D30(Aussie)/D44(LSD)/3.73s/1"MML/1.25"BL/OME Springs/UCF TT/33s
Build Thread: http://www.jeepinwv.com/forum/viewto...p?f=51&t=26137
SOLD-'96 XJ, Build Thread: http://www.jeepinwv.com/forum/viewtopic.php?f=51&t=6523
smccollamjr is offline   Reply With Quote Quick reply to this message
Unread 04-25-2014, 10:56 PM   #5
jagular7
Yah, line them up one behind the other. Measure the distance from the most front tires to the most rear tires. That's the length of deck you need. Now, you may have an issue with overhang off that deck length with certain states. Don't forget to layout your rigging to secure them to the deck.
After configuring the deck, you'll have to figure out if you want a bumper pull or a 5th wheel, cause its all about tongue weight and balance to figure out where the axles need to be. Then the size tires and axles to carry that kind of weight plus the trailer itself, etc. etc. etc.
Mike
Jagular
Lnxa, KS
97 TJ SE lifted, locked and rubbered for fun
94 YJ SE stock, 225s, Trail Tested
jagular7 is offline   Reply With Quote Quick reply to this message
Unread 04-25-2014, 11:37 PM   #6
jason280
It will be a bumper pull/tag trailer. Even though I know 28' would be perfect, I'm still trying to keep the trailer as short as possible. I'm pretty sure 26' will be adequate, but wanted to see what others were using to haul two Jeeps at once. Even though dual 6-lug (5k pound) axles would be sufficient, I'd rather go with dual 8-lug axles for the extra capacity. The trailer will also be used to occasionally pull a Kubota tractor with FEL, and the extra length will allow enough room to haul both a bush hog and disc plow with the tractor.
Unread 04-26-2014, 05:08 PM   #7
wilson1010
I can't think of anything to add to this.
Unread 07-27-2014, 10:48 PM   #8
Davetha
Davetha's Avatar
Around 30ft-32ft is ideal for towing two Jeeps. You can get away with around 24ft~ though but its not optimal. Not only is tying them down important, but balancing the trailer so you don't exceed your tongue weight and balance everything out.
Having a 5th wheel or gooseneck would probably be best for this application, but I've seen it done on a bumper pull.
So yes, 26ft will work, but its not perfect.
Davetha is offline   Reply With Quote Quick reply to this message
Unread 08-06-2014, 08:36 AM   #9
Leyva_WJawd
You know weigh stations are pretty easy to find online. They'll charge you about $10 to weigh your cars. In case you want to know the actual weight of your vehicles.
1999 Grand Cherokee Limited, 4.7L V8, QT II, AWD, Brush Guard, 31x10.5x15"s. BB otw.
Leyva_WJawd is offline   Reply With Quote Quick reply to this message
Unread 08-06-2014, 11:33 AM   #10
smccollamjr
The local Love's truck stop charges $12 for the initial weigh and $1 for a re-weigh if it's the same day.
Unread 08-09-2014, 02:58 AM   #11
wilson1010
Maybe they can measure how long the Jeeps are too. The OP was unable to do that on his own. Do you think they have a tape measure at the weigh station?
