Rules for trailering - JeepForum.com
Go Back JeepForum.com > General > Trailers & Towing > Rules for trailering
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineGibson WK HEMI 3" Catback - 5 Day Special!The ULTIMATE "Selectable" Locker System! Brough
Unread 09-22-2014, 07:50 PM   #1
rt4422
I have tried to search for threads on the rules and guidelines for towing your jeep on a flatbed trailer such as in gear/not in gear, where and how to strap down, but I can't seem to find any. I know I have read some in the past.
This will be my first time towing my jeep on a trailer and I want to check on some rules for this.
I have a manual so my first question is do I leave it in gear or in neutral? 4Lo in gear? Or just parking brake?
Secondly, strap to chassis or axles? From what I've read I'm leaning towards chassis... Will 4 - 2" ratchet straps with 10,000# breaking strength, one on each corner suffice?
If theres a thread on this, I will gladly accept the link...
Thanks
rt4422 is offline   Reply With Quote Quick reply to this message
Unread 09-22-2014, 07:58 PM   #2
SLADE
Secure the axles and the rest of the vehicle will stay in place.
Strapping to the frame requires securing the suspension. If there is any movement in the suspension when the frame is strapped you'll rip your straps and risk losing your load.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is online now   Reply With Quote Quick reply to this message
Unread 09-22-2014, 08:20 PM   #3
77351wcj5
Either method will work, just make sure your straps are pulling away from each other, not just straight down.
77351wcj5 is offline   Reply With Quote Quick reply to this message
Unread 09-22-2014, 08:31 PM   #4
white305
As far as rules go, some states require brakes on both axles of the trailer. I tow mine in gear, low range. I use axle straps and ratchet straps that I bought from Mac's. Nice stuff if you need to buy some. Four corners. If you tie into the frame you should crank it down to the bump stops to prevent shock loading the straps (no experience with this though).
white305 is offline   Reply With Quote Quick reply to this message
Unread 09-22-2014, 08:50 PM   #5
rt4422
Thanks for the input, fellas. I went ahead and ordered 4 - 10,000# ratchet straps and 4 axle straps since it seems like most people tie to the axle and it seems the most simple.
I was thinking 4LO in gear as well, just wasn't sure if I was missing a concept on how that's a bad idea.
Unread 09-22-2014, 08:54 PM   #6
GringoLoco
Agree with just securing the axle. I wish tow truck drivers understood that, I had my Jeep towed on a flatbed when I grenaded my D35. The halfwit driver strapped my wheels to the flatbed instead of just the axles, and somehow managed to bend one of my steel rims.
YELLOW Jeep Club Member #5606
13 mpg - edit: 12 mpg
No hi-lift on the hood (yet)
Odd noises
Still can't get it to take off from a treadmill....
GringoLoco is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 10:38 AM   #7
my996duc1
anyone have pics on how/where they are using the axle straps on the front axle ??
I've looked at my front axle and can't spot a good place to route the axle straps without going over something I don't want to crush.
I've been running straps through the front wheels and then also running a set of straps on the d-rings of the front bumper.... over kill with six straps (4 front and 2 rear) but I don't like any of my front strap locations and would like to find a good spot to use the axle straps on the front.
I keep mine in 4 low and 1st gear with the e-brake set. It has never moved on the trailer while towing.
_
2005 LJ Rubicon Sahara #0090 / MetalCloak'd / Currie 4" Lift with AntiRock / 35x12.50 GoodYear Kevlars / UCF skids
My build : http://www.wranglerforum.com/f5/rubicon-sahara-build-chronicles-328649.html
my996duc1 is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 11:26 AM   #8
little_Jeep
Asking about Trailering a Jeep is about like asking a political opinion. You talk to a 100 people, you get 100 answers.
Four individual tie downs. You debate chain, or strap. Taking one long chain or strap and running it from point A to B, C, & D doesn't count.
You debate cross or don't cross rear straps/chains.
Axle or suspension, I have seen the professionals use both. Jeeps have a lot of flex, if your tow rig is large, having a Jeep rocking & rolling on trailer may not be a problem for you. If your tow rig is on the small side, it might be a safety problem. You debate.
little_Jeep is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 11:36 AM   #9
mdm
Farm Wheeler
I tie down at both the axles and frame.
Straight forward from the front axle to tie down rings on the trailer bed
Crossed from the rear axle to the trailer bed tie down rings
Crossed from the front bumper D-rings to the trailer front rail rings
Straight from the rear bumper D-rings to the trailer side rail rings
I found that if I just went from the D-rings the rig would tend to shift a bit. If I just went from the axles the rig would get to bouncing on the trailer. The way I do it now - it doesn't move until I want it too.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 11:39 AM   #10
rrobbins
I put the jeep in 1st gear, usually low range, set the ebrake, axle straps around the inner c's and then go as straightforward as possible. For the rear I can just squeeze the axle straps next to the upper control arm mounts around the axle. They end up folded a little but they are beefy and have a fabric sleeve to keep from chafing. Again I go straight back with them. If your rig is super flexy and you have a small tow rig a few extra straps to keep the jeep from swaying help, however I never do it and have no trouble.
I don't cross the straps because if they are crossed, and one fails, the other will be pulling the jeep to the side. Also if the straps are tight they would have to lengthen for the jeep to move side to side. This has worked well for me everytime. One thing tho is I have to tighten my straps pretty good cuz they always seem to have just a little bit of stretch to them.
rrobbins is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 11:41 AM   #11
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Moved to Trailers & Towing Forum.
Wheelin98TJ is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 05:18 PM   #12
wilson1010
There are two conditions that you might want to consider when deciding how to secure your load. The first condition is if you are not going to have an accident. An accident would be an event that applies a lot more force than you can accomplish with your tow rig's brakes.
If you are not going to have an accident, then you are planning for keeping the rig centered on the trailer and not moving around, and not loosening the straps. For this plan you can use your ratchet straps on the axles or on the frame or both. And, you can crisscross them or not as you choose. The lower the angle between the tow point and the trailer, the less likely the straps are to loosen or allow the rig to move around.
Now, if you want to prepare the load for the unlikely event that an accident will occur, then you need to think about the task a little differently.
If you strap only by the axles, then it will take very little force to leave the axles on your trailer and the rig flying through the air. Think about the relatively tiny amount of force we use to snatch a rig out of the mud. Nothing near the forces that would be present if, God forbid, your tow rig would hit something solid. No one of us would snatch the rig out by the axles. I would not be at all surprised to be able to pull a front or rear axle right off a stuck rig.
So, if you strap by the axles, you will do a good job of salvaging your axles in an accident. But, your rig may end up in someones living room or, less desirably, pushing your forehead into the tow rig's dashboard.
And, the yellow straps have a breaking strength of say 10,000 pounds. Is that enough? I will leave the calculations up to others, but I would guess that if your tow rig stops quickly, say as a result of contact with a bridge abutment or the back of a loaded semi trailer, I think the yellow straps will fail.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 05:52 PM   #13
thantos858
1974 CJ5
Gotta look at the working load limit of your straps not the breaking strength. Average working load limit of a 2inch axle strap is around 3200 lbs and breaking of 10,000 lbs for a quality strap the cheaper ones are only around 2000lb working load and 6000 lbs breaking. My guess is most have the cheaper straps which aren't really good for a Jeep.
For the guys that like to tie to axles just remember you can bend your axles rather easily let alone other possible damage.
Personally I use 1/2in grade 70 chain and binders since I have access to them and attach to the frame. A 1/2in grade 70 chain has a working load limit of 11,300 lbs and breaking strength of 45,200 lbs. More than likely I will have my jeep still attached in a accident.
thantos858 is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 07:10 PM   #14
smccollamjr
After I get the straps tight enough to keep the Jeep from moving I put it in neutral. Then, after I get it strapped down tight I put it in 1st gear, low range, and set the e-brake. That way I'm not putting strain on the drivetrain if I don't tighten down the straps evenly. I strap it down by the axles. With my sway bars connected it doesn't flex enough to cause problems.
'00 TJ/4.0/NV3550/D30(Aussie)/D44(LSD)/3.73s/1"MML/1.25"BL/OME Springs/UCF TT/33s
Build Thread: http://www.jeepinwv.com/forum/viewto...p?f=51&t=26137
SOLD-'96 XJ, Build Thread: http://www.jeepinwv.com/forum/viewtopic.php?f=51&t=6523
smccollamjr is offline   Reply With Quote Quick reply to this message
Unread 09-25-2014, 10:08 AM   #15
MPond
Mac's makes nice stuff! I spent some time talking to them when I ordered my straps, and they recommend Not crossing your straps.
Their reasoning was that, if 1 strap failed, you'd still have 3 straps pulling in the correct directions (mostly front to rear, with only a slight outward angle), whereas a crossed strap needs it's opposite strap to pull against, or the vehicle will walk sideways and the strap will loosen.
2006 Black Unlimited 6-speed, Rubicon Express 5.5" Long Arm Kit
MPond is online now   Reply With Quote Quick reply to this message
