Right side trailer blinker/brake light not working, running light works fine - JeepForum.com
post #1 of 1 Old 07-21-2012, 07:49 PM Thread Starter
pmccoy9876
After searching here and the internet at large, I'm unable to find a lead for this problem.
Basically, I'm trying to figure out where in my F150's wiring the problem is. The symptoms are that the right side trailer lights have functioning running lights (work with the headlights) but the turn signal and brake light on that side do not work, regardless of whether the headlights are on or not.
So far, I've replaced the fuse in the truck, and I know it's not the trailer (which is a 7 pin connector) because I also have a 4 pin set of magnetic lights which exhibit the same symptoms.
Any thoughts on what would cause this? The only thing I've seen online is that "some trailers ground through the hitch," but that shouldn't be a problem with the 4 pin magnetic lights, since they have nothing to do with a trailer.
Originally Posted by MrNate View Post
Are you insane? Do you have any idea how many slip-and-fall accidents are caused by carelessly discarded banana peels? This is a crime of Vaudevillian proportions and must not be tolerated in a civilized society.
Originally Posted by RyanCJ2A View Post
I have no input of any value to this thread but those are awesome.
pmccoy9876 is offline
Reverse light that plugs into trailer light harness? heezy101 General Discussion 11 10-12-2012 02:22 PM
Trailer light issues REDLYNER Trailers & Towing 2 12-04-2009 03:15 AM
08 JK trailer light plug jnr0104 Trailers & Towing 3 12-10-2008 11:54 AM
Trailer Tail Light Veevog Trailers & Towing 3 03-10-2007 06:16 PM
Red Light Fine in NYC? hyedipin General Discussion 9 02-07-2004 05:58 PM
