02-07-2012, 12:17 PM
#1
Will these straps work to secure my jk from the axles on a trailer?
http://www.northerntool.com/shop/tools/product_200448636_200448636
Steve, Olean NY 2009 JK X 2 Door. Clayton 3.5, Tom woods Rear DS, 305/70-17 MTRs, 4.88s, Off road Evo Sleeves/Gussets, ARB diff Covers/Rear locker, Mopar Rails, Skid Row Evap Can Skid, Rancho oil pan skid, Rugged Ridge Bumper/prerunner, Smittybuilt XRC8. Build Thread http://www.jeepforum.com/forum/f22/steves-2009-2-door-jk-build-959234/ http://www.eriejeeppeople.com/Enchanted Mountain Off-road Crew--Olean NY
enchantedmountainoffroad@gmail.com
02-07-2012, 12:22 PM
#2
2006 Ram 1500, towhore, intake tune 285 70 17 KM2s 2001 18' Parker, crawler hauler
1997 TJ, Dad's Claytons 4:88s and stuff A TJ for Dad
1996 XJ, Gf's Project low on green
1992 YJ crawler, Caged, locked, ready to rock, on 33in pitbull rockers . Build thread the illusion of progress
North Jersey Jeep Club Secretary
02-07-2012, 03:19 PM
#3
Both of those options will work just fine.
79 CJ5. 258, T-18A, D20. 33s
01 Silverado DRW DD/tow rig
Military Jeepers
02-08-2012, 04:06 AM
#4
AS I always try to point out, if you would pull your rig out of the mud by the axles, then tying it down by the axles is about the same thing. Only if you pulled it out of the mud by the axles, you would have better control of the force being applied and people around you would think you were nutz.
Check your spring shackle attachment to the frame in the rear, that will be the only thing holding that rig on the trailer.
As for the straps. Whadda need the chain for? They come with hooks at the end of the straps for half the price. the chains don't add anything to the securement of the rig.
03 Rubicon; 99 xj with a bunch of stuff put on by somebody else; Unimog 406
02-08-2012, 09:04 AM
#5
I think the idea behind the chain was to keep the straps from getting cinched down over the edges of the trailer/stake pockets, lengthening the life of the straps.
I thought it was a cool idea, but not $40 cool
02-12-2012, 08:48 AM
#6
Retard Police
I personally tie mine down by the axle because the axle will stay stationary tied down even though the rigs suspension will bounce a bit. If you tie it off using the bumpers/frame area you have better completely compress the suspension. If you do not it could bounce enough for the strap to come loose. Just my 2 cents.
The stake pockets on my trailer are small enough that I can not get a double j hook strap end through them going through the inside, those hooks on the chains fit though. Eventually I plan to add some welded D rings throughout the length of the trailer.
Vote for the May TJ of the Month now!!!
ΜΟΛΩΝ ΛΑΒΕ
Originally Posted by TheBoogieman
Jeepinmichguy is a jerk.
Originally Posted by mrblaine
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123
you all have nice rigs, stop being f****** a**holes.
Special thanks to the following vendors for supporting the TJ of the Month contest:
02-12-2012, 09:12 AM
#7
I respect that choice which many persons make. I would just say that it is not at all necessary to compress to the bump stops to tie down the chassis. In any event, one could not compress to the bump stops with a ratchet strap unless the springs are very weak because a ratchet strap will only put about 600-800 pounds of force on the chassis.
It does give confidence not to see the rig moving as much with the axles tied down. I know the feeling of seeing the rig bouncing around in the rear view mirrors and don't disagree that that is disconcerting.
I just need to point out that if any real force is put un the trailer, the axles are a very poor choice to absorb all of that force because they are easily damaged or dislocated from the suspension. They are not made or attached with that type of force in mind. That is why we don't snatch our rigs out of the mud by the axles.
But, I accept that the axles vs. rig tie down thing is probably 50-50%.
02-12-2012, 09:35 AM
#8
Retard Police
ΜΟΛΩΝ ΛΑΒΕ
02-12-2012, 10:02 AM
#9
I sell trailers and tie down lots of vehicles. Most of the time the axle configuration is sufficient and is the only option on many newer/non-jeep vehicles. I do like to compress the suspension when possible in order to keep the vehicle from bouncing as much but we do it either way and both seem to work just fine
Mean Green Build-http://www.jeepforum.com/forum/f22/mean-green-build-college-budget-1164650/
'88 YJ SBC 350 w/ goodies, SM465 Transmission, Ford 8.8 posi rear, NP231 SYE'd, 4" RC Lift, 33x12.50 Goodyear Duratracs, Supertop, TJ Flares, Bedlined, etc.
02-17-2012, 08:46 AM
#10
Cheap insurance i learned while trailering bikes, run a bungee cord between the eyes on a strap. If you bounce and lose tension on the strap the bungee keeps the hooks in place. Youll never lose a strap that way.
Odds are im typing on a tablet. It takes too much effort to add some punctuation. Im lazy, get over it
Never underestimate the power of stupid.
02-17-2012, 11:14 AM
#11
Retard Police
That is a very good suggestion.  Thanks!
ΜΟΛΩΝ ΛΑΒΕ
02-17-2012, 02:10 PM
#12
The reason I don't pull my rig out of the mud by my axles is because if it's stuck in the mud it's barried to the axles and I don't want to use a shovel to dig it out. Also because my winch is mounted to the bumper not the axle.
That said I run chain and binder to the axles when on the trailer.
03 Rubicon on 36's and LONGFIELD CV's
ROCK'D-N-LOCK'D <-------link
02-17-2012, 02:37 PM
#13
I'm betting you have never even driven your jeep in mud deep enough to be up to the axles. Let's see some photos of you in some serious mud. And, if you use a winch more than a snatch strap, you're doing something wrong.
Here's one of me:
02-17-2012, 03:47 PM
#14
Hahahahahahaha I have a ton at home on my computer( I'm on my phone now and having problems getting into photobucket) that I'll post later tonight. And what am I supposed to "strap" to when I'm leading?
02-17-2012, 09:12 PM
#15
