-   Trailers & Towing (http://www.jeepforum.com/forum/f104/)
-   -   Questions about Dinoot Trailer Build (http://www.jeepforum.com/forum/f104/questions-about-dinoot-trailer-build-1535110/)
Berniebikes 06-11-2013 10:21 AM
I'm seriously considering building up one of the lightweight Dinoot trailer rigs for some camping/exploring. I'm looking at using the Harbor Freight #94564 frame but would like to run jeep tires rather than the 12" ones that come with the frame. That would give me better ground clearance and a wider selection of 15" tire sizes. It appears that the frame comes with M12 lugs (as opposed to the jeep 1/2") but has 5 x 4.5 lug pattern which will match up to the jeep wheels. Can anyone confirm this? It also appears the trailer tires have 0 offset so I'm wondering if I will need spacers to move the wheels out so they won't rub the trailer frame. Anyone with any experience or knowledge out there regarding this build?
superj 06-11-2013 11:51 AM
no but you can buy the spring mounts and new leaves and axles at tractor supply for super cheap so if you use it and want to modify those things to fit your needs, hit TS for the part. i know i have looked at their trailer build section of the store and thought of how much cool stuff a person could build
jscherb 06-12-2013 04:29 AM
Yes, the HF 94564 frame has a 5 x 4.5 pattern, and the lugs are metric. If you're going to run Jeep alloy wheels, you'll need to run spacers because the holes in the center of the alloy wheels are too small to fit over trailer hubs, so you can get spacers with 1/2" lugs so that the lugs will match the Jeep in both thread and bolt pattern. Here's more info on putting Jeep wheels on Harbor Freight frames: http://tventuring.com/trailerforum/thread-64.html
Also here's a thread with plans and instructions for modifying the HF 94564 frame specifically to fit the Dinoot trailer: http://tventuring.com/trailerforum/thread-118.html
Here's a frame running Jeep Moab 16" alloy wheels, all set up for the Dinoot:
http://i213.photobucket.com/albums/c...er/Tongue1.jpg
http://i213.photobucket.com/albums/c...nalTent3-1.jpg
If you've got any other questions about building a Dinoot kit, I should be able to answer them.
Berniebikes 12-30-2013 08:09 AM
Jcsherb, thanks for your guidance.
I went ahead and got the trailer and have it built up. I ended up extending the axle (cut it in the center, sleeved and welded it all up) plus used some 1.5" spacers so I could go to 1/2 20 lugs and not have problems with the wheel center. I'm using Grizzly wheels so to deal with the offset I would have needed nearly 3" spacers if I went with that alone (thus the axle extension). I looked into buying a new axle, but with the cost and shipping it was easier just to do it myself, plus I scored the spacers off ebay for less than $50.
One question, looks like you have rigged some sort of extension to the tongue to get a longer trailer(I'd assume the length will make it back easier). What did you use?? In the picture it looks like you have a receiver tube then the ball attachment forward of that. Did you consider a rock n roll type hitch or anything similar? Thanks
jscherb 12-30-2013 08:41 AM
Originally Posted by Berniebikes (Post 18950313)
Jscherb, thanks for your guidance.
Glad I could help!
When I shortened the 4x8 trailer to 4x4, I used the leftover frame rails to make a center backbone for the frame. I put receivers from HF on both the front and the back of the backbones; in the front for swapping couplers, and in the back for accessories like a bike carrier. The original 4x8 and the modified 4x4 frames are shown below:
http://i213.photobucket.com/albums/c...psd9607771.jpg
Step-by-step plans and instructions for the modifications are in this thread: http://tventuring.com/trailerforum/thread-118.html.
Yes, that's the main reason I put a receiver on the front.
http://i213.photobucket.com/albums/c...psc21fd9ac.jpg
The 3-axis coupler is my own design. Step-by-step plans and drawings for the coupler can be found here: http://tventuring.com/trailerforum/thread-65.html
http://i213.photobucket.com/albums/c...AxisFinal1.jpg
Sparrows 01-04-2014 05:53 PM
On a similar note, is there a trailer axle that takes 8 lug Ford wheels? Or 6/8 lug Chevy wheels? I'm putting full sized axles under my rig and I want my trailer to use the same wheels/tires so everything is interchangeable. Thanks!
Cheers
jscherb 01-04-2014 06:14 PM
Cheers
Here's a place that'll make you a custom width axle with either 6-on-5.5" or 8-on-6.5" bolt pattern hubs: http://kmtparts.com/axles-spring-mou...55-4-drop.html. They're $199 complete hub-to-hub (you supply your own springs).
Sparrows 01-04-2014 06:42 PM
oh man thanks! That's exactly what I was looking for. And for a reasonable price! :thumbsup:
cheers
Berniebikes 01-07-2014 03:50 PM
Jsherb,
hope you are weathering the cold fine up there in NY. Thanks a million for the details on the multi-axis hitch. I wanted one but not for the commercial price. Now I'll be welding mine up this weekend! I plan on ordering my dinoot tub in a couple of weeks. I noticed in your signature line that you did a fiberglass jeep tub kit. Was that a Dinoot or something else. Again, thanks for the hitch and other info
Bernie
jscherb 01-07-2014 04:50 PM
Originally Posted by Berniebikes (Post 19199210)
Jsherb,
Bernie
Bernie,
Yes, I designed both Dinoot fiberglass trailer tub kits. Both the Dinoot "j-series" Jeep-tub kit and the Dinoot "m-series" military replica tub kits are in production now. Both can be found at www.dinoot.com.
Good luck with your coupler project!
Jeff
http://i213.photobucket.com/albums/c...psdf6c445b.jpg
Sparrows 01-08-2014 01:09 AM
Originally Posted by jscherb (Post 19201234)
Bernie,
Jeff
I'd be VERY interested in the "M-Series" if you think it would be possible to build a hinged lid capable of mounting a roof top tent to. Whatdoyathink? Possible?
If so I'll think about ordering one next month when things get moving! :2thumbsup: :D
Cheers
jscherb 01-08-2014 05:58 AM
Cheers
It's more than possible :). Here's a hinged top/RTT platform on an m-series...
http://i213.photobucket.com/albums/c...psc37aa74e.jpg
http://i213.photobucket.com/albums/c...ps6697dba3.jpg
http://i213.photobucket.com/albums/c...ps5c890493.jpg
http://i213.photobucket.com/albums/c...psa49349aa.jpg
Sparrows 01-10-2014 04:45 PM
That's perfect! I checked out the site again and I don't see anything about the lid on there so I'm assuming it's a custom job? Is it glassed too?
Cheers
jscherb 01-10-2014 05:06 PM
Cheers
It's molded fiberglass just like the rest of the tub kit. I designed it to be an option to go along with the m-series. The company is just now finalizing the release of the tailgate version of the m-series, so they haven't gotten to getting the cover ready for sale yet. I expect they'll get to working on that next.
Here are a few more shots of the prototype cover before painting:
http://i213.photobucket.com/albums/c...ps9d555cd7.jpg
http://i213.photobucket.com/albums/c...ps52c67074.jpg
http://i213.photobucket.com/albums/c...ps63b1b780.jpg
The time now is 06:14 PM.
