question about tandem towing laws - JeepForum.com
post #1 of 7 Old 02-16-2013, 05:35 PM Thread Starter
Ripper3494
i have a question about tandem towing laws in Illinois and Indiana.
my plan:
2500HD silverado in front towing a 16' deck over trailer with a yj on it equipped with trailer brakes and behind that would be another stock yj being flat towed off a hitch on the back of the trailer
from what i'm reading this would be legal in these two states but i'm not sure if a CDL would be needed. the combined weight is less than 26,000 lbs but being that it is a double trailer type setup i'm not sure how that works.
thank you for your input.
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #2 of 7 Old 02-24-2013, 07:58 AM
MWilcox
Call the DOT, it's different in each state. I looked into it as well and found that no commercial licensing is required for recreational use. If you put a machine or any type of equipment on the trailer you are commercial then and need a CDL and double endorsements. Your flat towed jeep will need a braking system to be legally towed. The only other issue is total length, but you won't go over the max length with that set up. If you've ever been out west you will see it a lot. Pretty rare in our area though. Good luck!
'05 supercharged LJ Rubicon 6-spd, 4 speed Atlas, 6" Teraflex LCG pro, HP 60 front, Tera 60 rear, 5.38's, arb'd, full Tera skids, Raceline bead locks, 40" MT/R's, full cage, OBA, etc...
MWilcox is offline
post #3 of 7 Old 02-24-2013, 09:47 AM Thread Starter
Ripper3494
Thank you, I'm still debating though we'll probably just take 2 tow rigs to avoid the hassle. I don't want to have to try and explain to the police why it's legal if I'm not sure what I'm talking about
Probably sent from under my broken heep
build thread:
RC vs BDS
post #4 of 7 Old 02-24-2013, 11:27 AM
slickrocksteve
I have seen it done here in Calif, but also have seen the state patrol give folks headaches over this.
slickrocksteve is offline
post #5 of 7 Old 02-26-2013, 08:52 PM
TSEJEEPERS
Not sure if it is true or not but I have heard that the trailer must be a 5th wheel trailer.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #6 of 7 Old 02-26-2013, 10:01 PM Thread Starter
Ripper3494
I've been reading that as well
Sent from my hacked Kindle Fire using JeepForum
build thread:
RC vs BDS
post #7 of 7 Old 03-05-2013, 10:24 AM
DBLJ
DBLJ's Avatar
The first trailer can't be a bumper pull. Watch your max length too.
Buy my transmission cooler. Derale TJ cooler.
DBLJ is offline
