Pulling an RV (weight) - Page 2 - JeepForum.com
post #16 of 22 Old 04-02-2010, 08:33 PM Thread Starter
Culchie
I'm glad everything worked out for you and your towing experience. Here is what Chrysler told me:
Thank you for contacting the Chrysler Customer Assistance Center.
The maximum trailer towing weight is 2,000 pounds for this particular
vehicle since there is no factory towing package. If you as the owner
should add any towing items to the Jeep, we are unable to provide a
higher maximum towing weight since it did not come from the factory with
any of the items that youi as the owner may install now.
I then told them that I put a class IV hitch on the frame (V6 tow package only requires ClassIII). And asked what else I needed to add that would be the same as with the tow package. They told me just about the same thing.
The maximum trailer towing weight of 2,000 pounds would remain
regardless of equipment added to the vehicle. It would be your option to
research if anyone is willing to install the towing equipment and then
job rate your Jeep on their own.
I then asked the place I bought the Jeep from what the tow package consists of. They replied:
For your vehicle properly equipped is 3.73:1 axle ratio,Trans oil cooler,trailer tow wiring with 7 into 4 way plug adapter.The class IV is only advised with V8 engine,power steering cooler,trans cooler and wiring as above.Length (25ft limit) is very important due to sway conditions and control.
So they more less are telling me that the oil, trans. and power steering cooler make a 3000 pound capacity difference. So any ideas as to a used vehicle that would for SURE pull up to a 32' long travel trailer up to at least 6000 pounds ??
Culchie is offline
post #17 of 22 Old 04-08-2010, 09:54 AM Thread Starter
Culchie
Anyone know how the Commander v8 tows a 5000 lb. + RV ??
Culchie is offline
post #18 of 22 Old 04-08-2010, 10:38 AM
Ross
Originally Posted by Culchie View Post
]o they more less are telling me that the oil, trans. and power steering cooler make a 3000 pound capacity difference. So any ideas as to a used vehicle that would for SURE pull up to a 32' long travel trailer up to at least 6000 pounds ?? [/FONT]
When you say at least what would be at most. With that info I would recommend a 3/4 truck or more. Many half tons may be fine with 6k but the "or more" makes me not want to recommend it. In my experience (however limited it may be) All the ¾ town trucks I have seen come with a towing package. That doesn’t mean an equalizer, weight disturbing hitch or other equipment may or may not be needed when towing heavier loads. There is always that phrase "when properly equipped".
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #19 of 22 Old 04-08-2010, 10:59 AM Thread Starter
Culchie
6000 pounds would be my max. That's why I thought the Commander could handle it with the 7400 tow capacity. But all vehicles pull differently. I would definately get the equalizer and whatever else I need to make it tow better and be safer. That's why I'm checking things out very carefully. Thanks.
Culchie is offline
post #20 of 22 Old 04-12-2010, 06:47 AM
ptwelve
Before I had my motor home I had a 23' travel trailer. Wet weight of 4500lbs, 62 ft^2 frontal area, with the jeep at 5000lbs loaded. Dual cam weight distribution hitch, proportional brake controller
Towed wonderfully. Was much easier to drive, faster, more wind resistant, and stopped quicker than my stock 35' motor home.
Now I had a V8, so you will be slower, but it can do it and should handle and brake fine if properly set up.
Head over to RV.net for detailed info on setting up your tow vehicle.
ptwelve is offline
post #21 of 22 Old 04-12-2010, 08:11 AM Thread Starter
Culchie
Thanks for the reply. But the ones I want is up to 33' in length now. About 6600 UVW
Culchie is offline
post #22 of 22 Old 07-04-2010, 07:57 PM
kevin A Whitler
I pull a 25 foot Puma trailer with a Toyota 4 runner sr5 and a 4.0 v6, equalizer hitch, sway bars and electronic brakes.
The trailer weighs 5000 lbs, the Toys weight capacity is 5000 lbs. I'm at the max and the trailer pulls fine. The trick is not to be the fastest on the highway but consistent. I have not felt unsafe doing this, but then again I pull smart and think ahead when towing the trailer.
Good luck to you and always think safety when towing anything. Just remember, it is not how fast you get there but to get where you are going.
kevin A Whitler is offline
Pulling SBC cam bearings NewdRiver_ General Discussion 1 07-16-2008 11:02 AM
Me pulling out some taco's Airbug General Discussion 11 12-13-2006 06:39 AM
Pulling Teeth rjt36 General Discussion 19 10-12-2006 03:04 PM
Pulling Someone Out dazed General Discussion 15 09-23-2005 02:43 PM
ACK. Pulling my hair out over this Tri_X_Troll General Discussion 6 04-05-2005 10:44 PM
