pulling my yj behind pickup - JeepForum.com
post #1 of 4 Old 07-19-2012, 08:14 AM Thread Starter
scoggins
If put a front reciever hitch on my yj why couldn't I use a piece of thick walled 2inch with a pintle loop as a highway towbar??
scoggins is offline
post #2 of 4 Old 07-19-2012, 10:54 AM
MPond
I wouldn't recommend it.
There's a reason that every towbar out there has a triangle-shape - it's much stronger than a single bar between the Jeep and truck. Simply put, a triangle carries forces from any side equally across the other 2 sides. That is why it's the strongest shape used in construction & engineering.
2006 Black Unlimited 6-speed, Rubicon Express 5.5" Long Arm Kit
MPond is offline
post #3 of 4 Old 07-19-2012, 10:56 AM
Ripper3494
you hit the nail on the head, a straight bar wont be near sturdy enough
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #4 of 4 Old 07-19-2012, 11:09 AM
GunHo198
The other problem with the straight bar is hitch height. It won't be adjustable up and down enough to align your hitch. Maybe with an adjustable hitch. But not the best tow bar setup.
Ive been giving this some thought as well. The triangle tow bars are just so much easier to work with.
94 Jeep Wrangler 4.0 with AX-15 Trans.
4" Procomp Lift, 3" body lift, 35" BFG Tires, Ford 9" Rearend with NASCAR Detroit Locker, Super 30 Front with ARB, Onboard Air, Dual Optima Batteries,Warn M8274 Winch, and Bushwacker Fender Flares.
GunHo198 is offline
Newer pickup DD kairo General Discussion 34 03-15-2011 07:00 PM
Liberty Pickup Brassmonkey General Discussion 33 02-13-2009 05:26 PM
2yo + big Dodge pickup = bad Boreal General Discussion 35 07-20-2007 08:48 PM
the jeep pickup red96jeep General Discussion 8 07-16-2007 02:23 PM
Need a pickup 97sahara General Discussion 3 04-07-2004 09:49 AM
