PLEASE LOOK! should I even try towing like this? - Page 6 - JeepForum.com
post #76 of 81 Old 10-26-2012, 02:40 PM
Ross
Originally Posted by wilson1010 View Post
I think you two might want to go back and read my post. Sway results from bad placement of the load (usually too little tongue weight) not from overloading. The solution is to re-balance the load.
That makes more sense (if possible), I must have missed that part in your previous post.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #77 of 81 Old 10-26-2012, 02:43 PM
MPond
Yes - if possible. But if you are too overloaded it may not be possible.
**Edit: to clarify, I mean that if the load is too much for the tow vehicle, balancing may not be enough to eliminate sway.
2006 Black Unlimited 6-speed, Rubicon Express 5.5" Long Arm Kit
MPond is offline
post #78 of 81 Old 10-26-2012, 02:46 PM
Ross
Even if you are within weight and cannot/did not configure load to sit on the trailer correctly you could have issues swaying.
Ross is offline
post #79 of 81 Old 10-26-2012, 02:48 PM
MPond
I think we're saying the same thing.
MPond is offline
post #80 of 81 Old 10-26-2012, 02:54 PM
Ross
I think so, both weight and how it is disrupted has to be considered.
Ross is offline
post #81 of 81 Old 10-26-2012, 05:10 PM
wilson1010
Certainly, a trailer can be both overloaded and poorly balanced, but this rig was only very slightly overleaded. And, my experience is that an overloaded trailer pushes the tow rig, causes understeer and doesn't stop well. Wagging of the tail is caused by too much weight on the rear and not enough on the tongue.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
