Ok to flat tow with lockers front and rear? - JeepForum.com
post #1 of 17 Old 01-25-2011, 03:44 PM Thread Starter
jdub36
Ok guys after searching through 12 pages of threads about flat towing i could not find anything that fit my situation. I have flat towed my previous TJ but my new to me TJ is setup a little different. My 97 tj has 35in tires, a detroit locker in the rear, true track lunch box locker in the front, and a Teraflex 4:1 on the transfercase. I have read that it is ok to flat tow with lockers and i have read that the front wheels will not follow right. Does anyone have a final answer on this? I know that a trailer would be better for towing but i only tow one time every year so buying a trailer does not make sense. Does anyone have a final answer to this question for me?
Thanks,
jw
jdub36 is offline
post #2 of 17 Old 01-25-2011, 07:33 PM
kairo
kairo's Avatar
Thanks,
jw
the lunchbox will cause issues. I know this is a smartass answer, but if you only tow once a year, just beg, borrow, or rent a trailer
Was: 1979 CJ-5, 1982 CJ-7, 1995 XJ, 1991 YJ, 2006 KJ, 1979 F-150
Is: 2011 Ram 1500 Hemi & '02 TJ on 35's
kairo is offline
post #3 of 17 Old 01-25-2011, 07:52 PM Thread Starter
jdub36
By issues do you mean with the wheels turning correctly or is there something else i am missing?
thanks,
jw
jdub36 is offline
post #4 of 17 Old 01-25-2011, 08:36 PM
h2ojeep
1978 CJ7
I admit, I am pretty much spoiled as to trailering, and have always trailered my jeep(s). and regardless of the problems you may have with lockers, etc, I would still trailer just for tire wear reason.
With running Goodyear MTR with kevlar tires, (I run BFG MK2s) who wants to wear out those wonderful EXPENSIVE tires on pavement. Cost of buying one set of tires would buy you a good used trailer.
IMO, For once a year, I would rent a trailer, save the tires, and not even worry about all the other problems you will have with flat towing.
h2ojeep is offline
post #5 of 17 Old 01-25-2011, 09:03 PM Thread Starter
jdub36
Before going on my hunting trip last year i priced renting a car hauler from the local uhaul, i think the total was going to be over $800 for 3 days. I laughed my way all the way out the door. I will have to do some checking and see if i can find someone else to rent from. Maybe i can post an ad on my local Craigslist to rent from someone that just has a trailer sitting in their yard.
thanks for the help guys.
jw
jdub36 is offline
post #6 of 17 Old 01-25-2011, 09:15 PM
ajf1994
Trutrac is not a lunchbox locker btw... It is an LSD.
-SupportOurTroops-
High School Jeepers #361
Parrothead Jeep Club #46
37,xxx Miles
Originally Posted by XJ-Tim View Post
my welds look like popcorn with sprinkles.
Originally Posted by Benjamin Franklin
Beer is proof that God loves us and wants us to be happy.
ajf1994 is offline
post #7 of 17 Old 01-26-2011, 07:00 AM Thread Starter
jdub36
I just checked and i have a full case detroit in the rear and a detroit EZ locker in the front.
thanks guys,
jw
jdub36 is offline
post #8 of 17 Old 02-26-2011, 01:39 PM
92 Green YJ
92 Green YJ's Avatar
I have an ARB out back and a Detroit EZ Up front. when I flat tow my YJ I just disconnect both driveshafts. I disco the front shaft from the axle and bag and tape the ujoint so I dont lose the caps, then just bungie it up to the frame rail. rear I also disconnect just from the axle flange and zip tie up out of the way. Its worked well for me so far though im not sure about running with a full time locker in the back.
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #9 of 17 Old 02-26-2011, 05:43 PM Thread Starter
jdub36
My trip is in May so i have not had a chance to hook up my jeep and try to flat tow it yet.
i will have to try it to see how it works. I will have to go easy down the street i guess to see if i hear any grinding, haha.
thanks,
jw
jdub36 is offline
post #10 of 17 Old 02-28-2011, 02:33 PM
92 Green YJ
yeah best thing to do is to go ahead and hook it up and try towing it around town a little bit. that'll give you a feel for how it will tow and any issues you may have
My
post #11 of 17 Old 03-01-2011, 10:29 AM
chadsmeltzer
chadsmeltzer's Avatar
I have a similar setup to you, and the exact locker in the front. I have flat towed mine thousands of miles with no issue. Just remember to unlock the steering wheel and keep the towbar level so it will track correctly.
Sorta off topic, but in regards to wearing out the MTR/K, I have about 12,000 miles on my mine and many people have commented that they look new. Now if they were boggers or something I would not recommend flat towing with them.
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline
post #12 of 17 Old 03-01-2011, 10:52 AM Thread Starter
jdub36
I am not worried about putting the extra miles on the tires I will only tow one time a year and it is about 600 miles round trip. Not a big chunk out of the life of my tires. If i was towing once a month i would break down and buy a bigger truck and a car hauler trailer for sure.
thanks guys,
jw
jdub36 is offline
post #13 of 17 Old 03-01-2011, 08:28 PM
chadsmeltzer
Going 600 miles I would take the time to disconnect the driveshafts from the axle, even though it is not necessary. I have never done it, but my trips are only about 200 miles and I am lazy.
post #14 of 17 Old 09-24-2013, 09:35 AM
newfish1
I'd like some guidance on my setup as well, as I haven't found guidance for mine either. Dana 30 with ARB air locker in front, Dana 35 with Detroit locker in back.
newfish1 is offline
post #15 of 17 Old 09-24-2013, 11:31 AM
av8tr
av8tr's Avatar
I flat towed my TJ a couple of years ago, at the time it had an Aussie Locker in the front. It was about 2,700 miles total and I didn't have any issues what so ever. Having said that though, I will never flat tow that far again, even with no issues. That preference is mainly for saving the tires, as mentioned above. Other times I have borrowed a trailer and even rented one once. Even though the rental was reasonable, $200 for four days, I may just use the $200 as a down payment for one and just buy it. Fortunately I have a place to store one, which is not always the case for everyone and that adds more cost.
Bottom line to answer your question, I had zero issues flat towing with a locker as they operate as they do when driving it and allow the outside tire to turn faster when cornering. Just be careful where you go into as you can't back up safely while flat towing.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
2001 TJ
2007 KJ
2007 Dodge Ram 2500
av8tr is offline
Flat towing with lockers???? catsknr Trailers & Towing 2 07-27-2009 03:31 PM
Picture this, Pickup flat towing a jeep, flat towing a jeep Rumpeltiltskin Trailers & Towing 10 08-04-2008 07:29 PM
44 front and rear EaglesSJ General Discussion 1 08-15-2005 03:52 PM
Ok- tellico never sent the front lockers CETROV General Discussion 3 07-23-2002 09:28 PM
Ordered Loc Rite lockers for the front- CETROV General Discussion 9 06-21-2002 02:16 PM
