OD Towing with deeper gears? - JeepForum.com
post #1 of 5 Old 08-11-2017, 09:36 AM Thread Starter
-OIIIIIIIO-01
.....Mall Rated.....
-OIIIIIIIO-01's Avatar
So Wranglers are not good for towing to begin with, but I've been thinking about a small utility (or offroad ) trailer lately for camping.
That said, I have a 91 YJ 4.0 AX15 231J 8.8@4:10.
If I re-gear to 4.88 would towing a 500lb - 1500lb trailer be too much for the overdrive? Should I just stay in 4th gear?
My RPM's would be screaming in 4th with 4.88's I would think?
Hoping that someone that knows powertrain/ gears can shed some light on this. I searched and could not find the answer to my question.
thank you
91 YJ 4.0/AX15/231J AA SYE/ Tom Woods CV
3.5" BDS Springs / .75" Booms / 1"BL
HP D30 /Akebono's /1 Ton GM Crossover Steering
Ford 8.8 / Trac loc LSD w/ disc brakes
35x12.5x16 Nitto Trail Grapplers
Walbro255 MetalCloaks
-OIIIIIIIO-01 is offline
post #2 of 5 Old 08-11-2017, 12:21 PM
XJ_jeepin_06
XJ_jeepin_06's Avatar
With the ax15 it doesn't matter if you tow in OD or not. With 35s and 4.88s the jeep would have more power to the ground than you do currently with 4.10s. Will it not tow 1klbs in 5th currently? The "dont tow in OD" is for older automatics because they use fluid pressure to drive the output shaft. AX15 is gear to gear contact.
1997 TJ. Red. 4.0/AX15/NP231 SSSYE. D30/S35. Lokka/E-Locker. 4.10s. RC2.5" JK Rubi Tires/Wheels.
Antirock.
2000 2dr XJ D44HP/9in ARBs. 36" Iroks. Lots of skids/Lots of Damage. SOLD 6-6-2013
XJ_jeepin_06 is offline
post #3 of 5 Old 08-11-2017, 12:38 PM Thread Starter
-OIIIIIIIO-01
@XJ_jeepin_06
Thank you for the info.
I have not towed anything with the jeep is since the 35's and 4:10's.
Thanks again
post #4 of 5 Old 08-11-2017, 01:20 PM
Ross
thank you
Your trailer will be no problem with either gearing.
Not using OD or having special transmission settings (button on the dash) are for towing with autos to keep them from shifting to much and overheating the trans. With a manual you just go with what feels fight.
01 TJ,33X12.5Flaken WP ATs,Winch, ARBs F&R, belly up, some armor,4.0,5spd
Ross is offline
post #5 of 5 Old 08-11-2017, 09:24 PM
smccollamjr
I have TJ with NV3500, 35s, and 4.88s. Almost the same setup as you. I tow my 4-wheeler on a utility trailer. Total weight might be 1k lbs. it does fine. If you can use 5th use it, if not don't. It's better to rev the engine a little than to lug it. 4.88s with 35s is pretty close to stock gearing. Regearing from 3.73s to 4.88s was the best mod I've made. I actually enjoy driving my Jeep everyday again.
'00 TJ/4.0/NV3550/D30(Aussie)/D44(LSD)/3.73s/1"MML/1.25"BL/OME Springs/UCF TT/33s
Build Thread:
SOLD-'96 XJ, Build Thread:
smccollamjr is offline
