New gear/camping trailer - Page 2 - JeepForum.com
post #16 of 31 Old 03-02-2014, 10:12 PM Thread Starter
Blackhawk83
After looking at it, I'll need to use 5/8" bolts so I can interchange the 2" ball mount to pintle hook/ lunnete ring.
Blackhawk83 is offline
post #17 of 31 Old 03-02-2014, 10:31 PM
armyRN
armyRN's Avatar
Location: Longview, WA (one hour north of Portland, OR)
If you've never checked out the expedition portal you should check it out. They have a special section just for trailers, and they talk about teardrop trailers a good bit. You might be able to pick up some pointers.
http://www.expeditionportal.com/foru...ition-Trailers
armyRN is offline
post #18 of 31 Old 03-03-2014, 05:37 AM
jscherb
The "Trailer and Chassis Secrets" section of the Teardrops n Tiny Travel Trailers forum (http://www.tnttt.com/viewforum.php?f=35) is also a great place for trailer frame info. that section of the forum has the subhead "Ask questions about Harbor Freight trailers, or questions about building your own... "
"Whether you think you can do something or you think you can't, you are right" - Henry Ford
jscherb is offline
post #19 of 31 Old 03-03-2014, 06:08 PM Thread Starter
Blackhawk83
I got the hitch mounted today. Two 1/2" grade 8 bolts in the coupler and one 5/8 grade 8 in the trailer tongue. I might put another in later for redundancy. I finished tightening up the suspension and put the 15" wheels on. After that I had to take it for a test drive. It performed great and it is a huge difference from the 5x8 from TSC. No bouncing or wobbling. I'm very happy with the results so far.
post #20 of 31 Old 03-04-2014, 01:32 PM
TAS
TAS's Avatar
It looks very aerodynamic!
Todd
98, I6, 5spd, 4" Lift, 33's and a few other mods that get me there.
Tow rig - 12 F-350 4x4
TAS is offline
post #21 of 31 Old 03-10-2014, 09:57 PM
thantos858
1974 CJ5
Any more updates?
thantos858 is offline
post #22 of 31 Old 03-10-2014, 10:17 PM
PTee
^^^ what he said
2010 WK North Edition. QT2, loaded with Hemi Black WK # 102
PTee is offline
post #23 of 31 Old 03-11-2014, 07:12 AM Thread Starter
Blackhawk83
Sorry, I have been really busy at work. I went and picked up my cedar siding from the saw mill and came back with extras! I started the bottom storage box. I undercoated the plywood before attaching it to the frame. It is held down with silicone and I drilled and taped the frame for 1/4-20 bolts. The storage box is secured with construction adhesive and 3/8 bolts through the sides. I will take some better pictures of the box today. Next step is the framework for the side walls and install the sleeping deck.
post #24 of 31 Old 03-11-2014, 12:57 PM
PTee
I like this project, looks good. Are you going to need airflow to prevent mildew growth in those storage boxes, or is that not necessary? I'm looking to do some storage compartments in the future on my utility trailer.
2010 WK North Edition 5.7 Hemi, QT2, loaded Black WK #102
PTee is offline
post #25 of 31 Old 03-11-2014, 01:07 PM
theGiantPanda
Swap This...
theGiantPanda's Avatar
looking good....
when you have a minute, swap that hitch mounting bolt out in the tongue for a longer one, from the pics it appears that it is not long enough and not engaged in the 'lock' portion of the locknut. it needs to have at least a few full threads past the nut to be functional.
Keep progressing....
Originally Posted by CCJ View Post
Jesus. This is what heaven on 4 wheels looks like.
Hospital? What, are you suffering from Overextended Jeepaphelia or something? :)
I've never been poor, only broke. Poor is a state of mind. Broke is a condition brought on by Jeep ownership and a heavy right foot.
2006 Unlimited Redicon Panda Edition
RRI Long Arm...14" Fox CO's Front and Rear...D60 KP Front and D60 FF Rear... 5.38s spooled...40" Maxxis Trepadors...
6.1 HEMI...Atlas 5.1
5.7 HEMI 400 hp TJ Build
6.1 HEMI Ultimate LJ Rubicon Build
2.5 to 4.0L swap and build up
4.0 to 2008 5.3L GM LS in the Taco'd TJ [frame off build].....
My new DD Build, lift, 4.0 motor swap, done in 6 days?....
the new shop...
conversion, parts and wiring systems
shop email....
LIKE US on facebook.....
adding more daily
redrockindustries.net
theGiantPanda is offline
post #26 of 31 Old 03-11-2014, 02:36 PM
thantos858
1974 CJ5
Are you going to treat the lumber as you go along? Are you using a white wood as well?
The ceder has natural resistance to bugs and water If your going to do wood storage that has a chance of getting wet pressure treated, ceder or redwood are good choice.
post #27 of 31 Old 03-11-2014, 03:42 PM
PTee
Originally Posted by thantos858
Are you going to treat the lumber as you go along? Are you using a white wood as well? The ceder has natural resistance to bugs and water If your going to do wood storage that has a chance of getting wet pressure treated, ceder or redwood are good choice.
Resistant has a definition.
Those compartments are small. I would personally be concerned about mildew still. With temperature fluctuation and a porous material, in a sealed environment, you will get mildew.
It's unfinished so, I don't know if drawers are being added or a finished sealed paint or what.
I am interested to see the build and a concern of mine was mildew. After seeing the photo the second thing I thought of was airflow. Second after "oh cool"
PTee is offline
post #28 of 31 Old 03-11-2014, 04:33 PM Thread Starter
Blackhawk83
I will seal and paint the storage areas. I might even line them with cedar. The unit will be stored in a garage to keep it out of the elements. If it rains while we are out I will leave the storage doors open when we get back. The outside will be covered in 1/4" plywood followed by felt paper and then the cedar siding so I don't see the untreated white wood being a problem. I might spray it down with a clear coat before covering it for good measure. I made some progress on it today. I will take a few pictures after I get the garage cleaned up.
post #29 of 31 Old 03-11-2014, 06:20 PM Thread Starter
Blackhawk83
The add image option is not available for me right now. I will post ASAP.
post #30 of 31 Old 03-11-2014, 10:54 PM
bobdog
"cedar siding from the saw mil" - Say that 5 times fast! sorry but I thought it was funny. Really cool build.
Black Jeep Society
New Mexico Jeep Club
Atheist Jeep Society
Micro-Trailer Club
bobdog is offline
