Need Help - JeepForum.com
post #1 of 5 Old 04-04-2013, 10:48 PM Thread Starter
Marijke
Need Help
I currently drive a TJ Jeep manual, however its almost time to retire it. Due to the fact i will need a more spacious jeep. However, we just bought a coleman travel trailer.
GVWR 3850
Unloaded Weight 3156
Hitch Weight 460
I was wondering if anyone could suggest a jeep for me that can pull the trailer along with a great hunting vehicle. and would it be better if i got a manual or automatic if i am wanting to tow? It would be greatly appreciated.
Marijke is offline
post #2 of 5 Old 04-05-2013, 06:24 AM
thantos858
1974 CJ5
I don't remember the TJ tow specs but its close to that. A J series pickup, XJ or a grand would be able to pull that trailer. I think the newer wranglers also have a high tow rating. As for the trans it all depends what you like. A auto will save you from shifting is the biggest difference.
thantos858 is offline
post #3 of 5 Old 04-05-2013, 01:07 PM
Jason
Only the Wrangler Unlimiteds are rated to tow 3500 lbs. Short wheelbase Wranglers are 2K lbs. or less. GCs should be able to handle that fine. Really depends on what your budget is.
We're men! We don't need no stinkin directions!
Jason is offline
post #4 of 5 Old 04-05-2013, 08:02 PM
MPond
An LJ (TJ Unlimited) is rated to tow that, but I'd be hesitant to do so with one. It's just not the ideal tow vehicle. If you were going to do so, I'd recommend using some form of sway control to keep it in line.
But if you're going to buy a different Jeep to tow with, consider a Grand Cherokee. You ought to be able to pick one up used with a decent tow rating.
The WK2 (2010–present) is rated 7,400 lb for Hemi models and 5,000 lb for Pentastar models.
2006 Black Unlimited 6-speed, Rubicon Express 5.5" Long Arm Kit
MPond is offline
post #5 of 5 Old 04-20-2013, 08:11 PM
bbacus
Tow Vehicle?
If you upgrade your vehicle to tow the trailer, try to find a vehicle with the factory installed tow package. Usually this includes and additional transmission cooler, 4prong or 7 prong electrical outlets and different gear ratios. Don't tow this trailer with a TJ. A GC would do the job, but as always a pickup would be better.
bbacus is offline
