My tow setup - JeepForum.com
post #1 of 25 Old 05-29-2012, 03:12 PM Thread Starter
jonwood
My tow setup
People always want to know how other people tow there junk so here is my setup
Tow rig and trailer
Hitch setup
Chained up
I think I may get some J hooks for the front but this works well
03 Rubicon on 36's and LONGFIELD CV's
jonwood is offline
post #2 of 25 Old 05-29-2012, 04:00 PM Thread Starter
jonwood
Theres another way I do it on the front where I run the binder from the other side of the D ring so there is slack in the center. I should do it that way again. Lookin at it now I dont know what I was thinking this time. Oh well , I'll do it right next time haha
jonwood is offline
post #3 of 25 Old 05-29-2012, 05:51 PM
wilson1010
Where do I start?
Is that 1/4" chain? It look like 1/4" Tell me its not.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #4 of 25 Old 05-29-2012, 06:51 PM Thread Starter
jonwood
3/8, all my stuff is from the place I used to work at when I used to build tow trucks
jonwood is offline
post #5 of 25 Old 05-29-2012, 06:53 PM
wilson1010
Thank you. I can sleep easily.
post #6 of 25 Old 05-29-2012, 09:49 PM
99_TJ_Wyoming
lol, were you worried he would come to Ohio and threaten to drive near you?
99_TJ_Wyoming is offline
post #7 of 25 Old 05-30-2012, 08:35 AM
wolfcreek
Nice setup. The hitch extension picture is a little dark... Reese Titan? Torklift? Also: do you know how much weight is on your rear axle? I guess the WD must help.
wolfcreek is offline
post #8 of 25 Old 05-30-2012, 09:09 AM Thread Starter
jonwood
It's a torklift extension. I have the weight of the rear axle written down somewhere but I'm not sure if Incan find it anymore, but I'll try to look. And yes the weight bars are real nice. I towed without them for a long time but now that I know what a difference they make I'll always use them with the camper
jonwood is offline
post #9 of 25 Old 05-30-2012, 02:23 PM
Ross
I would get a different skid for the gas tank, other that looks good.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #10 of 25 Old 05-30-2012, 02:33 PM
wolfcreek
Another thing that occurs to me is that it looks like the way you have the front chain set up it is a single point of failure. In the unlikely event something breaks or comes loose both sides of the front will be loose.
post #11 of 25 Old 05-30-2012, 02:35 PM
wilson1010
Your excellent photos certainly bring into focus the issue of securing the rig by the axle tubes. Several comparatively delicate parts are all that secure your rig to the trailer. A few shackle bolts are really all there is. And, the axle tubes themselves are comparatively weak. I am certain that I could wreck one with a chain ratchet binder although your lever binder may be less likely to do so.
When forces are applied to the unsecured load above (like a serious jolt) and transmitted to the axles, you have essentially the same physics going on as if a person was trying to snatch a rig from the mud by the axles, which none of us would ever do.
But we have had this argument before and I am not trying to persuade you to change your methodology, just pointing out the reasons why securing the load or both the load and the axles rather than the axles alone is also a choice.
post #12 of 25 Old 05-30-2012, 06:58 PM Thread Starter
jonwood
Hahaha yep Im not tryin to argue that especially since you dont go to the bump stops the way you do it.
Just showin how I do it. This is the same way we would do a solid axle rig on the tow trucks I used to build.
I dont take any offense to your criticism since we are all after the same thing, SAFETY.
jonwood is offline
post #13 of 25 Old 05-30-2012, 07:04 PM Thread Starter
jonwood
Yeah I know what your sayin and I thought I explained in my second post but I may not have been as clear as I thought I was(no sarcasm intended)
I usually hook up my binders differently, where the lower hook on the binder is, is usually where I have the top hook of the binder. Then I take the lower hook and put it on the other side of the "D" ring so there is some slack in the middle between the "D" rings making it act as if there were two chains.
I hope that is a little more clear, next time I chain it down I will take better pic's
jonwood is offline
post #14 of 25 Old 05-30-2012, 07:15 PM
wilson1010
If you have a little more chain you can get a double line from both sides with one binder in the middle. Just run the chain back through the D shackles on the trailer deck the other direction and bind them together with one binder flat on the deck. Twice as strong.
You can probably get the idea from this photo:
post #15 of 25 Old 05-30-2012, 07:20 PM Thread Starter
jonwood
But I bought 2 binders so Im gonna use them haha
jonwood is offline
I have been setup! Hashbrown General Discussion 0 08-24-2011 02:25 PM
Good Z Day setup toates89 General Discussion 3 04-02-2009 03:12 AM
What setup is this? Sia Bani General Discussion 5 05-27-2008 07:00 PM
current tow setup... BigWaylon Trailers & Towing 56 01-14-2007 07:01 PM
Wiki setup Keith General Discussion 8 12-14-2006 06:42 PM
