My little trailer build - JeepForum.com
post #1 of 8 Old 07-02-2010, 09:25 AM Thread Starter
leolufse
Before:
Started with a Northern Tool 4'x4' utility trailer
After:
I added MT side biter wheels, BFG Dueler AT 30" tires, an Olympic cargo rack, and a diamond plate tool box for dry storage. Had to replace the fenders with a set from etrailer.com and some lighting and paint and here is the finished product:
leolufse is offline
post #2 of 8 Old 07-02-2010, 02:33 PM
Nickell80
1997 XJ Cherokee
I like how you kept it simple by just using a tool box. Are you planning to have the sames wheels/tires on the Jeep as the trailer?
White 97 2 Door 4.0 5 Speed XJ
Nickell80 is offline
post #3 of 8 Old 07-02-2010, 02:37 PM
KEH1997
Agreed, also because it allows you to remove it if you need more trailering space. Nice work!
KEH1997 is offline
post #4 of 8 Old 07-06-2010, 02:28 PM Thread Starter
leolufse
Thanks and no. I chose those wheels for the trailer because I like the look and they have about 3.5" BS. They worked on the stock trailer hub and I didn't have to modify the axle at all. But they would stick out way too far for my tastes on my rig.
The tool box isn't bolted down, so I can take it out easily for larger load. The rack is just held in with 4 eye bolts for attaching tie downs. It bolts right out if I need the whole trailer for something large, but both pretty much stay on most of the time.
I'm happy with how it came out, I get at least one comment on it whenever I take it someplace.
leolufse is offline
post #5 of 8 Old 07-06-2010, 05:52 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Question: How are you securing the toolbox if it's not bolted down?
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #6 of 8 Old 07-07-2010, 11:09 AM Thread Starter
leolufse
Well its surrounded by 3 sides on the front and the rear is very close to the front edge of the cargo rack. Also, I cut a piece of treadmill mat to lay on the floor of the trailer, it provides skid resistance, so I don't think its going anyplace. If I decide to run the trailer w/out the cargo rack, I'll just strap the box down.
leolufse is offline
post #7 of 8 Old 07-08-2010, 06:36 AM
FPKites
ZJjazzyJim
FPKites's Avatar
What happens when you hit a bump hard enough to bounce it? I'd strap it down regardless.
Just my
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #8 of 8 Old 09-26-2010, 08:27 PM
plym49
Really nice. The larger wheels, tires and fenders make it.
My experience with low, black trailers is that when backing at night you can lose sight of it. Suggest you consider adding a running lamp to the front outer lower edge of each rear fender. That way you always have something to see in your mirrors when backing up at night.
plym49 is offline
My Solidworks Trailer Build Libtekguy Trailers & Towing 65 02-15-2014 07:06 PM
Utility trailer build dylantheheeler Trailers & Towing 17 09-28-2010 09:26 PM
Off road trailer build binski Trailers & Towing 0 09-24-2009 08:42 AM
Take one - Trailer Build ArrizX General Discussion 4 07-08-2009 12:53 PM
offroad trailer build gribbles Trailers & Towing 11 06-13-2008 10:55 AM
