Marn's 1980 Jayco JayFinch6 Pop-up Build Thread - Page 4 - JeepForum.com
Go Back JeepForum.com > General > Trailers & Towing > Marn's 1980 Jayco JayFinch6 Pop-up Build Thread
Free shipping on Rugged Ridge XHD bumpersBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 09-17-2012, 05:18 PM   #46
studi30
You will need to replace the whole brake system, MC and wheel cylinders,maybe your brake lines as they rust through. Brake fluid is hydroscopic and absorbs water. That is why you should have your brake system flushed every 3 years. A shop can put a special strip into the fluid and tell you if it is good.
studi30 is offline   Reply With Quote Quick reply to this message
Unread 09-17-2012, 05:45 PM   #47
Dr. Marneaus
Station Wagoneer
Dr. Marneaus's Avatar
1973 FSJ Wagoneer
Yeah, I know. I've done the brakes on the waggy. Same reason you only use an unopened thing of brake fluid.
We'll see if i get around to checking it.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread: Marns '73 Wagoneer Thread ----- The Camper Build Thread: Marns 1980 Jayco JayFinch6 Build Thread
Dr. Marneaus is online now   Reply With Quote Quick reply to this message
Unread 09-19-2012, 10:50 PM   #48
Mickey_D
Marn, what's the bolt pattern on the trailer wheels?
I've got a set of 4 aluminum wheels (with tires) that I think came off a 1st generation Escort or Toyota (4x133mm I think). They've got (I think) 155R13's on them. If you want more info I'll take a pic or two tomorrow.
I could probably figure a way to get them to you (maybe).
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
Mickey_D is offline   Reply With Quote Quick reply to this message
Unread 09-20-2012, 09:28 AM   #49
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Hey thanks for the offer but they are 4 on 4 which is 4 on 111.3 or something bizarre
-Andrew
Unread 09-20-2012, 11:07 PM   #50
Mickey_D
Well, let me take a look at what they are. Maybe if they fit you can use them as beater spares. They're actually pretty funky looking, which translates to "pretty cool" when coupled to vehicles as old as both of yours.
________________
Unread 09-25-2012, 01:11 AM   #51
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Had some surprises waiting for me at home today.....the tread is great on these things too, like an AT
-Andrew
Unread 09-25-2012, 01:23 PM   #52
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
awwwwwwwwww yeah. Test fitted the new tires. all is well!
I'm going to need to notch the bumper though to keep it from putting pressure on the tire and damaging it.
-Andrew
Unread 09-25-2012, 01:53 PM   #53
en480c4
Are you going to paint the wheels black to match the Jeep?
Ian
2012 Sahara Tan JKU
en480c4 is offline   Reply With Quote Quick reply to this message
Unread 09-25-2012, 02:08 PM   #54
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
yes, jeeze, i've only had them for a few hours gimmie a break! They'll be painted by tomorrow haha
-Andrew
Unread 09-26-2012, 09:44 PM   #55
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Done.
forumrunner_20120926_194340.jpg   forumrunner_20120926_194403.jpg   forumrunner_20120926_194427.jpg
-Andrew
Unread 09-27-2012, 02:35 PM   #56
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
it's 'done' and just in the nick of time. We're leaving for Ely tomorrow at noon for a 2 nighter.
So, it went from this:
To this:
Went from this:
To this (now there is approx 7.5" or 8" from the axle to the ground):
From these:
To these:
From this:
To this:
Done!
Clean it up: Check
Paint: Check
Minor Interior Repairs: Check
Lift 3"-4": Check
Upgrade from 20.5" to 24.5" Tires: Check
Matching rims: Check
Best license plate ever: Check
-Andrew
Unread 09-27-2012, 04:43 PM   #57
RedZJ
Looks awesome. Anymore plans for it?
RedZJ is offline   Reply With Quote Quick reply to this message
Unread 09-27-2012, 05:32 PM   #58
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
use it?
-Andrew
Unread 09-27-2012, 05:37 PM   #59
RedZJ
use it?
id hope so.
Unread 09-28-2012, 12:34 AM   #60
Roobicon
Let's roll!
2004 Roobicon
Clinging to my guns and my religion
Roobicon is offline   Reply With Quote Quick reply to this message
