Marn's 1980 Jayco JayFinch6 Pop-up Build Thread - Page 5 - JeepForum.com
post #61 of 132 Old 10-05-2012, 11:31 AM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Well, successful trip up to Ely and back this past weekend.
Boilin' some brat's in beer before throwing them on the grill.
Made ourselves at home...a messy home...
All ready for the return trip:
Overall, it was great to have the camper. Its so nice to not have to 'go outside' for stuff, and to have all your gear in the camper, you can stand up, walk around, etc.
I diud, however, discover that my heater doesnt work. Pilot works, thermostat works, the blower works, but the burner would not light. I'm hoping its just a thermocouple, which will be an easy fix.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #62 of 132 Old 10-07-2012, 02:34 PM
Mickey_D
Hate to say it, but if the pilot is staying lit, the thermocouple is working properly. If the burner will not light it sounds like the gas valve isn't functioning.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #63 of 132 Old 10-07-2012, 04:23 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Hmmm. That's not good then huh?
-Andrew
Marn is offline
post #64 of 132 Old 10-07-2012, 04:28 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Nice license plate!
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #65 of 132 Old 10-08-2012, 05:26 PM
Mickey_D
I'm looking at the same problem with the pool heater at the place I work at. The valve STARTS at $275 and goes up depending on how good a one we want.
Now, granted yours is going to be a MUCH smaller gas pipe than our 500,000BTU heater uses, but it's still not going to be cheap.
________________
#4
Mickey_D is offline
post #66 of 132 Old 10-08-2012, 05:53 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
I'll pull the thing out, take it apart, clean it, etc and see where it goes from there.
-Andrew
Marn is offline
post #67 of 132 Old 10-08-2012, 08:58 PM
Mickey_D
Can you do me a favor and take a pic of the business end of the heater please? The burner, thermocouple, pilot, etc. Lemme see what system it is and I'll see if I can give some pointers of stuff to test.
________________
#4
Mickey_D is offline
post #68 of 132 Old 10-10-2012, 11:54 AM
PALMERC
ELY!!!!
My neck of the woods, good ole northern Nevada landscape...
Just returned from Elk hunt and your project is cool...
I just bought a CJ8 and plan on coming up with a little vintage project like u have done. Just hard to beat my wall tent
thanks for the ideas
PALMERC is offline
post #69 of 132 Old 12-01-2012, 05:06 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Well now...I got enough initiative to actually do something.
The front of my camper previously looked as such:
Judging by the fresh chips in my paint, and the way the thin aluminum sheeting looks like it was actually peppered with bird shot, i determined that this is from 30 years of having rocks flung at it by driving down dirt roads. Pretty sure I'm correct. Thats the only messed up part on the body of the camer, the rest is straight as an arrow!
So, I decided to fix this. A buddy gave me a chunk of diamond plate, and i went to work.
test fitting after the first cut and notch:
Now, i was retarded and traced the notch on the second side wrong, and cut it too far over (forgot to flip the template). I'll either leave it open or put the little piece back in, i dunno how much I care.
Got them both on there, and semi-permanently attached (drilled a hole in each corner, and used self-tappers to attach to the camper siding. i'm going to add 2 or 4 more screws to make sure its all secure. But here's they're just being mocked up.
Went back and chopped a hole for the crank handle, and mounted the door for that to the diamond plate itself. (again, not fully attached so dont mind the gap along the left side, it's not screw down tight)
Got it all finished up, again, still missing the last few screws.
Now here's where I'm stuck. Not sure how to 'finish' them, and what to do about the notch i cut out wrong.
I'd like to fill the notch with the piece i cut out, i can just JB weld it back in and it wont be too noticable. But do i paint the diamond plate to match the camper, or do i leave it diamond platey?
If i paint it, it'll look better, but it'll still require touch ups to the paint because it will still get chipped. Plus, it'll cover up the incorrect notch i made when i repair it.
If i dont paint it, it wont need as much attention over time, but the notch will be more noticable, and i think it looks kinda bro-esque. Like I should have my 4 wheelers and dirt bikes on top of it or something, on my way to the dunes.
LETS JUMP SOME DUNES BRO!!!!!!!!
No, but seriously, paint them or leave them silvery?
-Andrew
Marn is offline
post #70 of 132 Old 12-01-2012, 07:30 PM
XJAbuzer
This is a great addition to your waggy. I love it.
Well, the diamond plate would look much better painted the same color as the rest of the camper but then you have to worry about touching it up when more rocks hit it. I say use tint-able Raptor liner on the diamond plate...at least that is the route I would take.
1979 CJ-5 304 V-8, T-150 3 speed, Dana 20, Dana 30 front, AMC 20 rear, Sold
Anyways, I wanna go wheelin'!
XJAbuzer is offline
post #71 of 132 Old 12-01-2012, 08:43 PM
CoastieShep
Make sure you put some caulk behind there around those screw holes. Don't want water getting in there.
CoastieShep is offline
post #72 of 132 Old 12-02-2012, 12:44 AM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Not a bad idea....but $$$$
I had THOUGHT about running a silicon bead around the edges....but with the 2 times it rains per year out here, i'm not super worried about it. plus, there's not actually any way for the water to get 'trapped' behind the plates. it will all just run right out if it even gets in there. the siding ehin them is so dented in there's tons of air space.
-Andrew
Marn is offline
post #73 of 132 Old 12-02-2012, 01:26 PM
tj98
I kinda like the look and definitely the low maintenance of the diamond plate. The Raptor idea sounds good too other than the cost.
Just thinking out loud would a small piece of aluminum angle just big enough to cover that chunk placed on both side looks decent? It would look structural like a mounting bracket.
98 TJ - Sold
99 TJ - Mine
10 JKU - Sold
14 JK Unlimited - Wife's
tj98 is offline
post #74 of 132 Old 12-02-2012, 06:27 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Thats not a bad idea at all, plus it would add a little protection to the lip of the siding. Hmmm! I shall think about that.
-Andrew
Marn is offline
post #75 of 132 Old 12-02-2012, 06:48 PM
tsstoudt
Instead of U channel, maybe J channel would be better. Just a thought.
ΜΟΛΩΝ ΛΑΒΕ
tsstoudt is offline
Marn's 69 nova build! Marn General Discussion 14 08-09-2011 10:12 AM
What is your favorite build thread? Skytard General Discussion 8 01-20-2011 01:06 PM
Jayco Baja Pop Up Trailer - Have one? I have questions. Joe_Boatwright General Discussion 10 07-28-2008 12:07 PM
