Quantcast making offroad trailer - JeepForum.com
Truck-Lite 7" Round Headlamp Giveaway! - Drive OffRoad Gift Certificate Contest!
Go Back JeepForum.com > General > Tow Rigs & Towing > making offroad trailer
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSwag Off Road BIG-HIT TJ-YJ Rear BumperNEW Fawkes modular recovery & bull bar mounts for WJs.
Unread 09-14-2007, 01:41 PM   #1
cnskate
I picked up a cool little homemade trailer project for $50 that has coil springs and shocks on it. I'm planing on making a storage box for it then putting a rooftop tent on top. I currently has 9" wheels on a 4 on 4 hub on what looks to be a 2" axle or so. What do I need to do to put stock XJ wheels on it? Is it just a matter of slapping on 5x4.5 hubs on? I doubt I'll ever have more than 400-500 pounds of gear on there. With those size tires would a lack of brakes be a problem? I not planning on any real serious offroading with it.
cnskate is offline   Reply With Quote
Unread 09-14-2007, 07:51 PM   #2
RKBA
As long as your axle doesn't have metric bearings, it is in fact as simple as slapping on the 5x4.5 hubs. Stock Jeep wheels have a lot of backspacing; sometimes that is a problem on a trailer.
You should be fine without trailer brakes for something that light.
Got pics?
2002 TJ SE
2004 WJ Laredo 4.7
2006 LJ
2007 Rockwood Freedom 2280
"...in the GOP, enthusiasm is measured in Reagan units."
RKBA is offline   Reply With Quote
Unread 09-14-2007, 09:53 PM   #3
cnskate
Thanks for the reply. I will try and get some pics up. How would i know if I had metric bearings?
Unread 09-14-2007, 10:58 PM   #4
SlinkyTJ
This space for rent.
SlinkyTJ's Avatar
Tape measure? Actually, if you price out new hubs and bearings, it's almost as much as the whole axle... and buying a new axle would make sure you had the right width... I lucked out and found what I needed under an old boat trailer. A simple springover and I was on my way.
'97 SE
Lockers and stuff
SlinkyTJ is offline   Reply With Quote
Unread 09-15-2007, 06:50 AM   #5
RKBA
Look at the bearing and seal #s. The standard type will have a number marking such as L44649. The metric stuff is usually stamped 25M or 30205 or something like that.
This link has a list of pretty much all the common non-metric bearing and seals that you might see:
http://www.etrailer.com/c-bearings.htm
2002 TJ SE
2004 WJ Laredo 4.7
2006 LJ
Unread 09-15-2007, 06:55 AM   #6
RKBA
I just happen to have a brand new 2K rated 5x4.5 trailer axle on my garage floor that I don't need. It has 47.25" spring centers and 60" WMS to WMS
2002 TJ SE
2004 WJ Laredo 4.7
2006 LJ
Unread 09-15-2007, 07:31 AM   #7
FortCollinsZJ
Wow all this has inspired me, I wanted a rooftop tent, but now I think I'll make/build a trailer for the tent and gear. I plan on puting in a new rear axle as is, so my old D35 could serve as a good trailer axle.
Nothing here
FortCollinsZJ is offline   Reply With Quote
Unread 09-15-2007, 03:36 PM   #8
Terrain Twister
Terrain Twister's Avatar
Recycling at its best!
At that point where it's too much to list!
Terrain Twister is offline   Reply With Quote
Unread 09-16-2007, 06:40 PM   #9
cnskate
I'm thinking about just picking up a used job box like this one: http://www.professionalequipment.com/job-site-tool-box-656990/tool-boxes/, flipping it over so it opens to the side, bolting it to the trailer, bolting the Yakima rack for the roof tent ontop, maybe reinforcing it, maybe not, then going camping. What do ya'll think?
Unread 11-03-2007, 11:32 AM   #10
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
you could probably find a dana 35 for free to get the correct width and lug pattern
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS!
Big-n-Broke-YJ is offline   Reply With Quote
